Page 163 of 169 FirstFirst ... 63113153159160161162163164165166167 ... LastLast
Results 1,621 to 1,630 of 1687
    Jun 2005
    #1621
    Quote Originally Posted by xwangbu View Post
    Tagal ng spare part from LG for our indoor unit.
    Almost 3 months na wala pa din.
    Me naglinis mali ang pagkakakabalik sabi ng technician.
    Attachment 43102
    Under warranty ba? Kung outside warranty, try getting the parts sa stores in cainta. I found one sa facebook. Ordered evaporator and got deliverd to my house in about 3 hours
    Sent from my 2107113SG using Tsikot Forums mobile app
    Sep 2010
    #1622
    Quote Originally Posted by sirkosero View Post
    Indoor unit out of warranty na.
    Thanks sa tip.
    If wala pa din update bukas e i-try ko maghanap sa FB.
    #1623
    Attachment 43102
    are these two statements, linearly related?
    or are they two un-related issues?
    Sep 2010
    #1624
    Hehe
    Doc - related. Mali baklas during linis kaya naitawag sa svc center. Me parts na need palitan kaso by order pa yata.
    Jun 2005
    #1625
    Thanks sa tip.
    Try calling this number or reach out via facebook. Thats where i got parts for my 10year old LG aircon
    Frid-Aer Aircondition trading 09532272174
    Attachment 43105
    Jan 2009
    #1626
    Please bear with me....
    We replaced the split-type A/C in the bedroom because it developed a leak that no technicians were able to find or fix. Long story short, the new A/C is installed and that's the end of the old A/C. However, the air flow doesn't quite reach my side of the bed.
    I sleep on the side of the bed near where the split-type A/C is, while my wife sleeps on the opposite side. On the old A/C, the vent louvre's movement has a lot more range and can reach my side of the bed, even down to my nightstand, without issues. We set the A/C at 26°C for comfort cooling and energy efficiency. That said, the louvre is set to Auto and I am accustomed to direct cool air reaching my side of the bed.
    The new A/C however, has a lot less range on the louvre movement and maxes out about halfway on the bed. The wife is getting the cold air while I'm borderline sweating. It eventually get's cooler throughout the evening but it's not very conducive when you're still trying to fall sleep.
    Question: Will those add-on/clip-on air deflectors I see online address my situation? This item in particular... https://shopee.ph/Air-Conditioner-De...0-141be0fbc899
    Here's a rough illustration to help visualize what's going on....
    Jul 2013
    #1627
    we installed one in the office... just observe where the cold air goes... on our first try, the cold air was pushed to where the AC would suck air, so the AC thought the room was cold already.
    Jun 2011
    #1628
    Puwede din may extra fan para i circulate ulit ang cool air.
    Jan 2009
    #1629
    Quote Originally Posted by bxr monkey View Post
    Already setup the Vornado for the next few nights. Pero, temporary only. It's an unnecessary ~50W of additional electricity consumption every night. I hope the deflector works well enough.
    Jan 2009
    #1630
    Had a eureka moment last night.
    The louvre is operated by a stepper motor and the aircon logic module controls it. Every time the A/C is turned off, the louvre resets to its Home position, which is closed. When you turn it on, the logic module turns the stepper motor a preset number of rotations to take the louvre to a position where it can then begin its up and down cycle.
    All I had to do was influence how far back the new Home position should be by stuffing a plastic packaging foam (secured with double-sided tape) between the louvre and the vent. The result is that the louvre's new Home position is now lower and so, the up and down cycle is also lower which makes the airflow reach my side of the bed.
    Had the most comfortable sleep in weeks.
    I'm still considering if I should make it look more elegant. But since this is hidden away in the bedroom, I really couldn't care less. I just wanted my sleep back.
Split Type Aircon: Which is best?
