Page 124 of 169 FirstFirst ... 2474114120121122123124125126127128134 ... LastLast
Results 1,231 to 1,240 of 1687
    #1231
    i agree.
    pressurized water is the better choice for AC coil cleaner.
    some products work thru acid, which can eat thru already-thin segments of the metal coils, resulting to holes.
    the same with alkaline-based cleaners.
    but because they are convenient to use, compared to the alternative, they tend to be popular.
    #1232
    Just clean with water from not so loud pressure that could damage the alum fins. Don't use cleaners or lye to clean the molds, bilad lang sa araw.
    As for the inverters ang unang bumibigay ay mainboard since DC switching power supply ang gamit to turn DC motors, parang PS ng computer at LED TV's. Ang nirerecommend nila yung Daikin na designed ang inverter sa wide input voltage parang up to 90 to 450V at surge na 650V AC?
    Kung patibayan lang, mas matibay ang traditional mechanical thermostat, ang panira lang talaga ay electronics at sensors.
    Oversizing by 150% is fine di bale sobra wag kulang dahil na overwork ang compressor. Wag din babad sa aircon na sarado bintana baka ma CO2 poisoning po, at matutuyo lalamunan nyo at uubuhin prang symptom ng COVID19.
    #1233
    Ang dapat linisin sa AC ay yung evaporator at condenser radiator, thru pressurised water pump.
    We know but we are in the context of not able to get it service because of the China flu.
    If walang pandemic eh di hinde na pinag uusapan dahil mapa service na.
    Jan 2008
    #1234
    Maganda din palang panglinis ang fabcon sa evaporator. Nakita kong ginamit nung nagpapull down ako ng indoor unit
    Sent from my Redmi Note 8 Pro using Tapatalk
    Jun 2005
    #1235
    Hinde yan ang dahilan baka talaga meron na kalawang yun fins sa gilid-gilid tapos pag spray mo malakas talag cleaning agent kaya naalis yun kalawang.
    I clean aircons myself using pressure washers. Only 1 time i decided to try coil cleaners. Supposedly spray and iwan lang and use the aircon para magpawis at malinis. Wala naman kalawang before i used the mckenic solution. Nagkaroon about a month after. Ganda ng timing IMO
    Sent from my MI MAX 2 using Tapatalk
    #1236
    Quote Originally Posted by sirkosero View Post
    Gumamit ako neto. after 1 month, butas fins ng aircon. Haaay. Nung pinagawa ko, may signs of corossion yung aluminum
    Buti nabasa ko ito. Will stay away from those sprays.
    Yep bro Daikin claims their can handle high and low voltage. For FTKC series at least. Not sure for other models.
    As for cleaning, yung pag baklas lang naman problem ko. Masyadong mabigat ang kamay. Kung yung cover ng window type nga napuputol ko yung hinges, ito pa kaya.
    Na-appreciate ko yun LG split ko. The cover for the filter is thick, the snap-on feels like it will last 10yrs or so. The Split Gree's I have are slightly thinner compared to the LGs. Both have bad mesh filters though. I wish they were finer to avoid clogging the evap.
    #1238
    madalas bro pag sobrang fine, nag yeyelo din evap kahit bago yung AC (1 year old)
    if familiar ka sa 3m filter, yun ginamit ng friend ko sa AC nya. nagtaka bakit di nalamig nag yelo na pala
    Sep 2010
    #1239
    How about Matrix brand? Any reviews? They’re relatively cheaper than the other brands.
    Plan to put a 2.5 split type for the house. It’s an open type living, dining, & kitchen. Sqm is a bit over the required area. I saw that max for a 3.5hp is 43sqm. I measured the whole area & it’s around 48sqm. I haven’t subtracted the cabinets of the kitchen yet though. Would that be ok? I’ll probably just use electric fans to compensate if it’s not cool enough?
    the compressor will never even reach 10-50% regulation during the day time. regulating that 20C will be difficult. is the ceiling insulated? using fans do not drop the temps. the AC will still try to reach the target temps, this means the compressor will run more than 50% (power consumption of almost 1500w? guesstimation lng)
    no name brands might not have spare parts readily available though these won't fail that fast.
Split Type Aircon: Which is best?
