Results 1,121 to 1,130 of 1687
- 54,202
December 30th, 2018 11:04 PM #1123
Parang sinasabi niyo mag-Vios nalang lahat ng tao kasi pag high end na kotse na maraming features mas maraming pwedeng masira.
Well ako ok lang yung tradeoff na yun basta ayoko ng panget at maingay. [emoji23]
December 30th, 2018 11:08 PM #1124
December 30th, 2018 11:11 PM #1125
- Jun 2015
- 2,751
December 30th, 2018 11:17 PM #1126Was planning on having holes for window type a/c punched through the walls prior to the turnover of our house but, alas, we lacked the funds to purchase a/c units then (actually, ngayon na 5 months after wala pa ring funds) para makuha yung dapat na sukat. Now, split na lang ang pipiliin ko talaga dahil laking hassle na kung magpapabutas pa nang malaki sa pader.
Pag split-type ba butas lang ba para sa tubes ang gagawin? Papano wirings? May wall sockets na kasi sa walls for a/c. Magagamit ba yun?
Sent from my ASUS_T00J using Tapatalk
December 30th, 2018 11:20 PM #1127
So to summarize:
Window type:
Pros: Simple to install and maintain
Cons: Panget itsura, maingay, limited inverter choices
Split type:
Pros: Looks clean and unobtrusive, higher EER vs window (even inverter window), quieter
Cons: Maselan maintenance and kailangan maingat installation
Between the two, yung cons ng split type pwedeng mamitigate if you install properly a d get a reputable brand. Travs already shared very helpful advice on how to mitigate the cons of a split type (thanks a lot bro!). Yung cons ng window type yun na talaga yun wala ka na magagawa.
To each his own, but after weighing all the factors, split type preference ko.
December 30th, 2018 11:50 PM #1128
Some splits require the power source outside by the condensing unit, some by the interior unit. Consult your supplier/tech on the chosen brand/model's requirement. It's ideal to install on perimeter walls (as you would a window) & try not to embed lines. The drawback? It's not gonna be pretty outside as it will be inside. The shorter the line route, the more efficient.
On conrete wall boring for Window units, it's a simple cut & chip. An hour or 2's work. To prevent wall repainting, precision measurements, alignment & edge cutting are needed inside & out. It's possible to chip thru a clean rectangle. The vertical dimension of the hole should be about 15mm over the Window AC's vertical side measurement to allow for sloped install.
Anytime, good sir. Enjoy your new ACs.
- 54,202
December 31st, 2018 12:01 AM #1129nagpabutas kami dati ng aircon rectangulo. no problem. no issues. no regrets.
...as long as there is no compromise in structural strength.
years later, we replaced the old aircon with a smaller, newer one. we could have spent more, but... pinasakan na lang namin ng kahoy yung butas, at pina-beautify yung paligid.Last edited by dr. d; December 31st, 2018 at 12:10 AM.
December 31st, 2018 12:13 AM #1130
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
