Page 112 of 169 FirstFirst ... 1262102108109110111112113114115116122162 ... LastLast
Results 1,111 to 1,120 of 1687
    #1111
    Why would they downgrade?
    Collateral damage from maintenance, leaks, repeated repairs, replacement (the chipping, masonry work, paintwork, floor & wall rehab, etc) can consume patience & tolerance. They downgrade to the real 'upgrade' of simplicity & practicality...the window.[emoji4]
    #1112
    Basta ako personal experience ko mas okay split type. We used to be all window-type before. Ngayon isa nalang yung window type namin, nasira pa. So now I have to buy 3 aircons instead of just 2. [emoji23]
    Super mas tahimik when I switched from window to split. Also the aesthetics of the room, sobrang mas malinis tingnan.
    Never naging bothersome for me maintenance. Tagal na rin naming naka-split type sa bahay and never ko naexperience yung mga hassle na sinasabi dito. Kaya nga kung first-hand experience ang best basis, ok na ok ako sa split type.
    Nov 2017
    #1113
    Mukhang me bad experience si travajante sa split type.. Well look for good installer and invest on good quality foam insulation sa piping.. Use 1" size pipe as drain pipe. Importante kung maiiwasan yung mahabang linya.. Tama ka mas malapit yung blower sa condenser mas maganda [emoji16]
    Nov 2014
    #1114
    They both have pros and cons. For me, split type is for aesthetics. It's just weird that before my split type would leak every six months while I never had a problem with window type even if I don't have it cleaned for years. What I don't like about window type is the hole in the wall (which is minor).
    #1115
    Quote Originally Posted by maxpedition View Post
    I have one split type gumamit ng 40+ feet of tubing dahil sa likod ko pinakabotnyin outdoor unit para hinde nakikita sa harap ng bahay
    #1116
    My exposure is a bit different. We get called to restore whatever the AC guys can't put back post-repair/replacement.[emoji17]
    #1117
    In other words you get called when there's a problem. Which is why our experiences are different.
    #1118
    And mga assuming mga naayos ni Trava wala ng naging issue so walang problema pala talaga split type a/c
    #1119
    There's no fun in fixing flaws caused by those outside our coverage. Hence, we try to provide detailed guidelines for the AC guys to comply w/ on new installs....to prevent split-trauma, sir.
    #1120
    Nah, I just shared the pros, cons & measures needed. We even specify a minimum of 1.25" PPR drain, not blue. Splits are ideally installed along perimeter walls, where possible, to avoid lines running thru ceilings. If unavoidable, the insulated lines must be laid on gutter trays or thru pipes...I can go on & on.
    Though I find joy in those of others, leak therapy isn't fun. Leaks can leave indelible scars, literally & figuratively.[emoji17]
    Please don't get me wrong...I'm not anti-anything here. Just sharing to help prevent splitphobia.
Split Type Aircon: Which is best?
