Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 62
    #21
    dual core na.
    i've heard na yung bagong MS Vinta requires a dual core processor to run optimally.
    para mahaba haba na rin buhay ng investment mo.
    Sep 2006
    #22
    Quote Originally Posted by alwayz_yummy View Post
    ok..di ko pala magagamit sa asus p4s8x-x ko..hehe...basta po ba alin dyan sa sinabi mo pang chipset/socket?
    Opo, follow niyo lang po yan.
    Sep 2006
    #23
    Quote Originally Posted by happy_gilmore View Post
    dual core na.
    Actually, hindi po. Kahit yung mga P3 ay makakapagpatakbo pa po nito, 800Mhz up.
    Eto po yung guide: [SIZE=1]http://www.microsoft.com/windowsvista/getready/systemrequirements.mspx
    [/SIZE] So bale pasok pa rin yung laptop ni threadstarter.
    #24
    You have to determine kung ano primary use mo sa PC. Kung single threaded better yung mas mabilis na clocked proc. But in general windows performs better kung dual proc.
    Personally, id get the dual core then overclock it :-)
    Aug 2006
    #25
    kahit san mo tignan.. dual core
    panu ba ang dual core? two processor o single lang?
    Jul 2005
    #26
    syempre dual-core kung kaya naman ng budget mo. unless napakalaki ng difference nung processor speed, saka mo na iisipin kung san mo ba talaga gagamitin. at least medyo mas matagal ng konti maluluma yong setup mo.
    and of course, sa pinagpipilian mo, double ang memory(adds speed) and bigger harddisk space pag dual-core ka...so no-brainer to go for the dual-core kung kaya ng budget mo.
  7. #27
    so inshort dual core is different fron dual processor..diba may board na dual processor?
    Jun 2006
    #28
    Core Duo or Core2 Duo much better
    #29
    Quote Originally Posted by dur3x View Post
    Basically two processor dies in once chip.
    #30
    if you are not into graphics intensive aps (like games or vid editing) then a single core will already work for you. just make sure you have sufficient memory (512MB or 1GB) and a decent vid card.
    Jul 2005
    #31
    sa pagkakaintindi ko, dual-core is a single physical processor having 2 cores and requires compatible motherboard as well. dual processor is having two physical processor and requires motherboard which can accomodate two(or more) processors.
    Aug 2006
    #32
    awww... two core mold into one! sick! anyway.. nung bumili kami laptop.. kita ko brochure nung apple G5 ung desktop nila.. quadcore 2.0.. tama ba? tapos can support up to 16gb off memory.. awts! sarap ng ganun!1
    Apr 2005
    #33
    Quote Originally Posted by mazdamazda View Post
    same position as M2, go to dual core if your are more on video graphics if not single core speed is enough for normal activity.
  14. #34
    pardon ulit,ha... so, whats the diff between having a core duo vs dual processors?aside sa 1 vs 2,ha....avantage/disadvantage lang..
    pwede bang gamitan ang xp ng dual processor?
    Jun 2006
    #35
    You'd be surprised to know that Core2 Duo actually consumes 30% less power (therefore longer batt life) at about 10x (or more) the speed compared to single core
    Jul 2005
    #36
    main difference? price. as one article put it:
    ...the move to dual-core is definitely a win for consumers. Since they are more affordable than dual processor computers, but offer the same or better performance, they are becoming the standard for modern computer systems.
    unless siguro nag-se-setup ka ng server, you're better off sa dual-core. read up na lang to have the full technical details.
    http://www.pugetsystems.com/articles.php?id=23
    #37
    Quote Originally Posted by Kikkomann View Post
    yes. definitely it will run there. but take note that i've said in my previous post na "optimum" ang runtime nya sa dual core processors.
    tatakbo yan, pero ambagal.
    and yes, the microsoft vista requires at least 512 MB RAM.
    Aug 2003
    #38
    physically, iba ung dual core sa "traditional" dual/multi processor systems. but in essense the same: you get two processors to do your bidding. mas mabilis pa nga since physically the connections between processors/memory are shorter.
    try running task manager sa windows;if you have a dual core cpu you'll get two separate CPU utilization charts. cool.
    #39
    but current games are not designed to exploit the power of these dual core procs. not yet, but maybe in the years to come, it will. AFAIK, if your into multitasking, then these procs are for you.. if not, you're fine with single procs, but then if you're buying a new PC, better get these dual procs for future hardware and software compatibilities.
    Mar 2005
    #40
    will it improve my computer processing if I use dual core, I surf multiple windows, load and edit with photoshop and word, download from *******s, and watch quicktime video or play itunes music all at the same time. and mostly wireless na ako sa bahay
Single core vs. Dual core
