Ok po, so that mapping function is single use only. It can't save multiple zones, thus the map is only for efficient and directive cleaning. Thanks sir, nice inputs for consideration.
Xiaomi. Mine has been serving me well for the past 1.5 years with no issues. There's a newer version with stronger suction and a mop feature - sells for around 12k in Lazada, even cheaper than when I bought my gen 1 vacuum from Xiaomi's store (15.5k there).
Will cleaning the robot vacuum take almost the same time as manually vacuuming the room? ...
Hmm might be longer. Mine takes 20 minutes to clean my living room and dining area. When I clean it manually, it takes me about 10 min because I only focus directly on the dirt I see. If I were as thorough as the robovac, it would likely be the same.
madami namna affordable sa Lazada
Buy Robotic Vacuum Cleaners at Best Price Online | lazada.com.ph
cheapest legit seller na ba yan bro?
edit; bro found this
https://shopee.ph/product/15287380/7...7-1602118099.9
legit kaya?
Sent from my Redmi Note 9 Pro using Tapatalk
Why not the newer model, which is also cheaper? Same seller (Lucky HR). Has stronger suction (2.5 kPa vs 2.1 kPa) and mop feature.
Edit: Biggest drawback of updated version (1C) is that it doesn't have LIDAR. So just weigh if that matters more than the stronger suction and mop feature.
Xiaomi MiJia 1C Review: Impressive Cleaning Performance at a Reasonable Price
How do robovacs clean the floor under the dining tables and chairs? Will it go around each foot of the chairs?
Signature
Yes it goes around each foot of the chair/table. This is the cleaning path it takes, you'll see umikot talaga siya around each chair (you'll see the circular motion marked in red)
Yung ilalim naman like under my couch and cabinets (marked in yellow), dadaanan niya rin.
