Results 21 to 21 of 21
- Nov 2009
- 3,484
February 20th, 2015 09:58 AM #21Check the ip settings. Since there is no router that assigns an ip, you need to manually set a point-to-point ip on both devices, or make your PC the DHCP server. Cross and straight cable should both work since most Ethernet automatically negotiates transmit and receive(link connected status on your PC is your indicator). Prolly, your PC and NAS retained the ip but doesn't know what MAC address to route the traffic because of missing gateway.
high idle RPM at engine start
