Page 2 of 13 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 130
    Jul 2006
    Bago nalang yong iverter type 30 to 50% na mas matipid sa kuryente
    Does it make some weird sound? Did you defrost recently?
    I never defrost It's full of ice na nga. Turned off the ref. Hopefully tomorrow when I turn it on it will be okay na
    How about the door? Lapat pa ba? Dikit pa ba yung magnet or madali na sya buksan?
    I meant if I will call the hotline of Panasonic or just look for any refrigerator repair shop. Premature ata doc for an 8 yr old ref to need repair?
    panasonic service center and "authorized service center", are one and the same.
    defrost her, first.
    that might be all that you need.
    the fact that it is full of ice, means it's still cooling.
    but ice is a good insulator against more cold.
    turn off the ref, open the doors, and point a running electric fan into it.
    this will make the defrosting, faster.
    be prepared for water puddling on the floor.
    Jan 2016
    Is your ref, a single door type, with the freezer at the top? These types I think get their cold from the freezer, so if it's iced over, then this function is blocked. Sana nga makuha sa defrost. What I do when we had this type was turn it off at night when the ice gets thick, for regular defrosting
    Sent from my Mi A1 using Tsikot Forums mobile app
    "frost-free" models are nice,
    but i believe they consume more electricity.
    Jan 2009
    Some "no-frost" refrigerators don't have a manual defrost button. It usually runs as a timed event. When the program comes up (usually through a mechanical timer), the compressor and fans turn off then a heater near the evaporators fires up to melt the ice. Typically, the ice don't get too thick and the heater duration is enough to melt everything until the cycle to turn on the compressor and fans comes up.
    However, if the condensate drain is clogged, that will cause condensate water to back up and turn to an ice block. This will usually block the intake vents so there'll be little to no airflow. The mass of the ice can be too much even for the heater to melt in time. And even if it does, with the drain clogged up, there's nowhere for the water to go after it melts. As soon as the defrost cycle is done, it's turned back into a block of ice.
    This recently happened to our LG no-frost ref of 15 years. They needed to de-clog the drain and do some general cleaning. There were a lot of gunk on the evaporator condensate catch pan.
    Our older no-frost ref had a similar issue but it was a problem with the heater thermostat. It stopped working so even when the defrost cycle was on, the heater didn't work. This caused excessive icing and neither the freezer nor the ref compartment were getting any cold air.
    Yup lapat pa naman
    defrost her, first.
    The ice at the bottom freezer is so thick! It took 24 hours to defrost, there are still some ice left beneath the plastic but not so much. I have to turn the ref on na because I am afraid the food will spoil
    It has a bottom drawer freezer (which I hate) Defrosted it na, hopefully nga it works
    I think this is what happened to our ref because there is a thick super tigas ice block that formed. The catch pan also had so much gunk that looks like algae (yuck) I cleaned it up and there's clear water na on the catch pan.
    Turned the ref on again. Freezer is working na but it seems like the ref still isn't getting cold
    Jan 2016
    Cathy, did you di the "leak test" sa door? Ipitin mo paper in between and see if you can pull it daw, I've never done this pero I've heard it several times na
    no but I will do that later nga
    Mukhang may bara nga kasi after I defrosted at natanggal yung visible na block of ice e lumamig na yung freezer pero yung ref mahinang mahina pa rin
Refrigerator is not cold but Freezer is Working-recommend replacement
