Results 11 to 15 of 15
June 24th, 2009 12:01 PM #11
You need an 802.11g (Wifi-G) router at the least. No need to open your door.
Better if you can buy an 802.11n router, it has a wider range even if you only use g-compatible devices.
802.11g has a top speed of 54Mbps, 802.11n has a top speed of 600Mbps.
You're a lawyer, aren't you? Configuring a wireless router should be easy for you.
No need to bring your desktop PC even if you ask the store personnel to configure your router for you. But you should bring your netbook along, so you can test if they'll indeed connect with each other. Just take down notes so you can do the same procedure on your other PC's at home.
June 24th, 2009 12:24 PM #12
The G version should be fine, if the area is just small. The 54 and 600 Mbps is a connection from your end to the wireless router only, thus cant be maximized if only have a 256K pipe to the internet. N by the way is the newest IEEE standard in the wifi category.
- Pros of 802.11g - fast maximum speed; signal range is good and not easily obstructed
- Cons of 802.11g - costs more than 802.11b; appliances may interfere on the unregulated signal frequency
- Pros of 802.11n - fastest maximum speed and best signal range; more resistant to signal interference from outside sources
- Cons of 802.11n - standard is not yet finalized; costs more than 802.11g; the use of multiple signals may greatly interfere with nearby 802.11b/g based networks.
June 24th, 2009 12:42 PM #13
From what I've read over at TipidPC, it's useless to get a Wireless-N router if you have a Wireless-G device. The router will revert to Wireless-G specs.
I should know. Just bought a Buffalo Wireless-N router last Sunday. Eh yung laptop pala ng brother ko, G spec lang. Sayang pera, kasi doble ang mura ng G kesa N. (puwede naman bumili ng Wireless-N card, kaya lang dagdag gastos).
July 11th, 2009 10:43 AM #14
July 11th, 2009 08:43 PM #15
Si Lola Techie.... Kayang-kayang sagutin ang lahat nang iyan!!!
8202:sampay:
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
