Results 1 to 10 of 20
January 14th, 2004 11:13 AM #1
Anybody used this device as seen on TV. Totoo kaya eto Php 2,680 lang ang presyo. Bibili sana ako kung totoo eto. Ang laki ng matitipid 30% daw according to the ads.
"Here is a smart way to save up to 30% of your electrical bill. This new generation device can filter the supply voltage while improving the efficiency and power factor of your electricity consumed.
This Power Energy Saver can potentially save up to 30% off your electricity bills simply by improving the efficiency and power factor of electrical appliances. The device is able to store electricity for 5 to 10 seconds and release it for use during the downside supply. It can also improve safety by reducing the overheating of electrical wiring, hence reducing the size of wiring and copper loss.
One unit of this device will work on the whole circuit in your house as soon as you turn it on. Our field testing for most homes have consistently shown that one unit of the Power Saver will save 3 to 4 Kwh per day, based on electrical consumption of 30 Kwh per day. The amount of savings depends on few factors, such as the type of electrical appliance use and the amount of electricity use.
In addition to extending the life span of appliance motor, this device also reduces the reactive power generated by inductive loads, It helps the utility companies by eliminating interference to the power supply.
Suitable Enviroment : Shop, home, restaurants, office, school etc.
Power Test by Manufacturer
Before Installation of 'Big Power" 1P30 Energy Saver (Measured Values) After Installation of 'Big Power' 1P30 Energy Saver (Measured Values)
IL (A) Power Factor Real Power (W) Is (A) Power Factor Real Power (W)
1.108 0.545 138.8 2.254 0.270 140.0
2.263 0.356 279.0 1.857 0.653 278.9
3.405 0.534 419.0 2.131 0.853 418.0
4.480 0.543 559.0 2.833 0.856 558.0
5.680 0.534 698.0 3.780 0.802 697.0
6.800 0.537 839.0 4.780 0.762 837.0
Summary
POWER ENERGY SAVER will allow you to enjoy your comfortable lifestyle without worrying about your electricity bills. In fact this advance energy saver can reduce your electric consumption and therefore your electricity bill.
POWER ENERGY SAVER is designed using advance components and technology to reduce the energy wastage caused by the motors like the Air-con, Refrigerator, fish pump, Lighting, computer etc."
January 14th, 2004 11:50 AM #2
bibili din ako sana neto dati eh, kaya lang wala rin akong nakuhang feedback from friends who are actual users, puro written testimonies lang pinakita sa akin ng ahente.
i'll monitor this thread, interesado ako eh. ;)
January 14th, 2004 02:17 PM #3Originally posted by nap123
Summary
Moreover, Meralco lang ang may power factor adjustment, so even non-residential but non-meralco-supplied consumers ay di magbe-benefit dito.
Kung bibili at magi-install kayo nito, I would suggest na ang bayad is based on savings. Kung ano lang ang savings for the month, yun lang ang ibayad until fully paid. kung wala savings, wala bayad. Dapat pumayag supplier sa ganitong payment scheme kung talagang confident sya sa product nya.
Opinion at suggestion lang po.
January 14th, 2004 02:57 PM #4
Di ba pag hindi mo ginamit yung alloted consumption mo eh tataas pa din ang electric bill mo dahil dyan sa lintek na PPA na yan?
Anyway, better if you can ask for a demo. Titingnan mo lang naman ang metro mo kung bumagal eh di ba?
January 14th, 2004 03:58 PM #5
I just talked to the seller of this sa ads tv tel 721-000. Ang pagkasabi sakin pwede daw ibalik kung d daw talaga makaka save after 2-3 months of used. Bale sabi sakin mga 15-30 percent daw ang savings sa electric bill. This was design mostly daw kung gumagamit ng motor ang device like aircon. Tatlo pa naman ang aircon namin. pero malamig pa ngaun kaya d pa matetest kaya sa summer nalang ako bibili. I hope worth it eto.
January 14th, 2004 04:17 PM #6
true sinabi ng ad, it will lower the energy usage of electric motors but not electronic appliances like tv, computers, etc. it will work with electric fans, air conditioners, refrigerators, water pumps, basta may electric motor. power of electric motor = amps X voltage X power factor. since the power factor is normally 80% then there is a built in loss of 20%*** in the power that meralco supplies to all of us. theoretically the maximum power savings will be the amount of power factor correction and limitted only by the efficiency of the motor. so if it corrects the power factor from 80% to say 90% then that will be savings = 10% X motor efficiency in terms of power consumption (of electric motors only). if it corrects the power factor by 20% then it's savings = 20% X motor efficiency.
***this 20% built in loss in supplied electric power is due to the fact that the power generation is 3-phase, the power wave lags the voltage waves by 30 degrees resulting in a power factor of 0.80 or 80%.
so adviseable yan if you have airconditioners, electric fans and water pumps. pag lights, tv, computer and other electronics lang nasa bahay mo, then it's useless.
di lang ako agree dun sa claim na 30 percent savings kasi how can that possibly be bigger than the correction in power factor (1.00 - 0.80 = 0.20 or 20% maximum)?
January 16th, 2004 12:11 AM #7
Sana nga this product could help. If it could, wouldn't it be listing as it's clients top industrial/manufacturing companies? Imagine if you could get even 10% savings on 1m+ power bills...
- Nov 2002
- 116
January 16th, 2004 12:30 AM #8large customer with power factor problem will not going to use this device. they will definitely use capacitors.
- 3,754
January 16th, 2004 02:15 PM #10
the device works on motors like fans and refs... but if you have electronic device like computers, TVs, etc. it doesnt work.
Yup sobrang hassle ng mga truck sa marcos. Mas mabilis pa rin talaga sa kennon. Kaka akyat ko lang...
Tarlac-Pangasinan-La Union Expressway (TPLEx)...
