Page 1 of 4 1234 LastLast
Results 1 to 20 of 71
    My 3 yr old Lenovo is dead. It won't turn on. The battery indicator is just red. I tried removing the battery and using just the adapter but it won't turn on. I hope only the adapter is the issue because I've had problems with it before.
    I've been calling Lenovo in Taguig. Uminit lang ulo ko. It's too bad that the villman in Salcedo village and Amorsolo are closed. I've been a loyal Villman customer for more than a decade because their tech guys are magaling, accommodating and mabait. Now I don't know where to go
    BTW I'm never buying Lenovo again. Lousy support/after sales.
    safest route is via PC Express. There is one in Amorsolo near Eurotel, or the one in McKinley Parkway. however, i can take a look at it first so it can be diagnosed properly before you bringing it to a service center.
    lenovo? i had great experience with it. been using it for 10 years now. walang nagiging problema. your unit which is only 3 years old is still new/young to die out this early.
    Sep 2013
    Madam pls visit the site tipidpc.com > key in "laptop repair" in search box > select forum topic. so many choices ng repair shops dyan pero choose mo yung madaming positive feedbacks from the members, the more positive feedbacks, the more reliable the shops. oh sya para hindi ka na mahirapan pa pls click the link below. goodluck
    TipidPC.com | Topic Search - laptop repair
    Sira yung adaptor. Does anyone know where I can buy a lenovo adaptor? Wala kasi sa Villman.
    Oct 2015
    Try msi/ecs shop. They are accredited by most laptop brands. It's at BGC, ground floor of phil plans bldg. Nasa vicinity sya near Toyota Global. The bldg is along Kalayaan.
    Quote Originally Posted by car_fan View Post
    That's the shop recommended by Villman. Sobrang hirap tawagan. It looks like I have tp go without calling.
    May parking ba in that area?
    Jan 2012
    You could park in Valkyrie but its still 2 blocks away. I had my laptop fixed there before, their service is ok.
    Oct 2015
    You can go there as a walk-in customer. Yes may pay parking yun phil plans bldg. Just tell the guard that you have a transaction at msi. When do you plan to go? Punta ko dun this week.
    If the power adapter is really dead, then it wouldn't matter. But, did you try the little things first such as keeping the power button pressed down for a minute?
    ^yup, try to do a power cycle first.
    Quote Originally Posted by benchman View Post
    I already did that. The cord of the adapter is worn out na rin e. When villmam used a different adapter it worked
    Thanks. Not sure yet. I'll keep on calling. I really wanna avoid going there only to find out that they don't have stock of the adaptor
    If your laptop is common, someone may have the (universal) power adapter for your laptop model. From my experience, more often than not, it's not on stock (especially older models). I often ended up buying one through mail order. My kid's HP laptop is on its third power adapter and my 2007 Toshiba is on its second.
    It's Lenovo G470. They said I need an adapter that is 20v (3.25 mah). What's a good brand of adapter?
    Please help me in what type of adapter I should get
    If you want the same exact power brick, look up the model number of your power brick (PA-1650-56LC) and use that information. If you want any replacement (aka universal) power brick, just type your laptop brand and model number + "replacement AC adapter" in Google. I'd be surprised if a shop has your power adapter. Where I am, it was always "special order." Might as well order it myself.
    My kid is on her third power brick. She broke the original and the first replacement because she kept bending or crimping the thin cable where it comes out of the brick. I told her if she's not more careful, that's it. She's on her own.
    Anyway, you can try these. I have no experience dealing with PH shops. I can't vouch for their authenticity.
    Lenovo 2V 3.25A 65W original AC adapter (charger) | Ikaw Na Buy and sell Philippines Free Classified ads
    Lenovo 2V 3.25A 65W original AC adapter (charger) For Sale Philippines - Find 2nd Hand (Used) Lenovo 2V 3.25A 65W original AC adapter (charger) On OLX
    Actually, it's the same guy on two different ads.
    Jan 2012
    You can also buy a universal adapter, its usually a little cheaper and works just as well.
    Thanks! I think I'll just buy a universal adapter. Villman had one with different "heads" but the guy said it's not compatible with mine because it's 70 watts.
    Make sure the universal power adapter mentions compatibility with your exact laptop brand and model and/or the PA-1650-56LC. I mean the sales associates probably know what they're doing. But, it wouldn't hurt to make sure.
    Sep 2012
    You can try sa Glorietta, 3rd floor halos katapat ng BPI branch na kahilera ng Buffet 101.
    I forgot the shop name pero nag iisa lang kasi sya dun na mapapansin mo na halos parts and phone accessories ang tinda sa wing na yan. Makikita mo din sa display nila sa loob puro mga adaptors.
    Twice na ako nakabili sa kanila one for Asus laptop and another one for HP...
    Sent via Tapatalk
LAPTOP repair in Makati or BGC
