Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
    Aug 2003
    #21
    Quote Originally Posted by TON_ton View Post
    Lenovo dami ko nakikita nagamit
    fyi, Lenovo has embedded spyware installers in the BIOS, not sure on which models specifically.
    Jan 2012
    #22
    Asus is usually the non-chinese best value. A lenovo is ok though.
    Aug 2003
    #23
    Quote Originally Posted by viper888 View Post
    Technically Asus is Chinese(Taipei) ^_^
    i've no qualms about Asus, it's just that imho, they don't have a decent 11.6 in offering right now. Chromebook specs are a bit tight for me
    Jan 2012
    #24
    Well I trust taiwanese products a lot more than Chinese products. You should check out apple if youre will to strech your budget.
    #25
    out mo na chromebook. i have one and i really feel i can only do so much on that unit.... although there are offline apps that you can use there, it is still not enough.
    i only use that for browsing and for light emails.
    you can also look for Dell.
    Oct 2015
    #26
    I've had 4 Acers already. the last one which I'm currently using now is 7 years old, core 2 duo, without any issues.
    Jan 2014
    #27
    I'll stay away from acer. Unang laptop ko nasira disc drive after 2 months. Yung sa kapatid ko naman na huling bili nasira hard disk after few months also. Warranty claimed naman parehas. Yung pinaka huli kong company laptop, acer rin. Sira flex after 1 month. Yung lenovo na inissue sa akin last time tumagal ng 3 years gumagana pa ngayon kaso pangit na dami na kasing basag/crack madalas kasi malaglag. Hehe.
    #28
    Quote Originally Posted by luis_ View Post
    i have used acer twice in the past.
    replaced them both because of cracked/damaged hinges, which resulted to problems with the flex and the LCD.
    durability, i would go for asus, lenovo and dell.
    Aug 2003
    #29
    Starting to get purple flashes on my Dell whenever the cover get a little bent :p
    Just curious, how much would you spend on a "pang laspag" laptop? My personal limit is under 20k.
    Aug 2003
    #30
    Any Asus X302LA owners here? Ok ba sya?
pls suggest an 11.6 inch laptop
