Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    guys,
    1. whats the difference between Memory Stick Micro (M2) and Micro SD?
    2. is it true that anything more than 1GB is not advisable for Phones?
    imo
    1) mas maliit ang M2 than the micro SD. SE K800i and 610i uses M2. Earlier models dito like the 600 and the 750 uses the micro SD.
    2) not necessarily.... but most phones developed still don't have the capability to handle more than 1GB kasi these memory modules (> 1GB) have not yet been developed prior to their release. theoretically, a software upgrade on the fone should make it possible to handle more than 1GB memories.
    hth
    Sep 2004
    I used to think that M2, like all Memory Stick variants, is exclusive to Sony. That is, until I saw Memory Stick units made by different manufacturers.
    Some handset models, such as the Nokia 6300, can handle up to 2GB of removable flash memory right out of the box. MicroSD cards are already available in as high as 8GB of storage, although SD cards at and beyond 4GB are already classified as 'High Capacity', and will only work with SDHC-compatible devices.
    Quote Originally Posted by wildthing View Post
    imo
    Almost same size lang ang MicroSD and Memory Stick M2. These two types of memory cards are not interchangeable. And I don't think the older SE models used MicroSD, I think they used Memory Stick PRO Duo.
    Quote Originally Posted by rion
    Although most current phones should be able to handle up to 2GB memory cards, they tend to slow down considerably with greater than 1GB memory cards because it takes more time to access the files of a higher capacity memory card.
    and M2 cards are used for sony products only, unless some other brands have jumped on the bandwagon.
    Quote Originally Posted by ssaloon View Post
    Samsung phones also use M2.
    ^ really? i thought they only used micro sd cards
    mahal pa naman ng M2 compared sa micro SD.
    Sorry sorry, MicroSD pala yung Samsung. Just checked my wife's U600.
    yung nga ang hassle s sony... ang mahal ng memory cards...although nagmura na rin naman ngayon... my 1GB M2 used to be P3200 (about a year ago)... now the same 1GB M2 is being sold at P1250+ nalang
    Bumagsak na presyo ng M2, which is good.
    I've also seen adapters that makes MicroSD work in gadgets that uses Memory Stick and vice versa, which is good.
    My phone uses M2, my camera and handy cam uses memory stick. Ok rin when you could interchange them all.
    Ok I see, Salamat sa info guys.
    bumaba nga ang presyo ng M2, though I'd hope the price is as low as microSD's.
    kalahit lang ang price ng microSD compared sa M2.
    sa cdrking website kasi, double parin ang presyo compared to MicroSD.
    Nov 2006
    I asked a shop at the SM Manila, its 2GB M2 is at P2100. Is it cheap?
    Dec 2002
    ^ I'd say its cheap...test mong maigi if its working...ang hirap pa naman maghanap ng M2-2gb sa market ngaun...if you don't mind, saan po dun exactly? been on the hunt for this kasi...TIA!
    Nov 2007
    sa cd r king kayo bumili
    too late when i realize that i made a mistake when reformatting my sony memory stick from my old but still reliable digicam. infected kasi siya ng ravmon worm... during the process of eliminating it some files can't be deleted because they are not visible leading me to this problem. stupid me... thought the same as a normal thumb/external drive. gurus, help naman kung anong magandang gawin apart from getting a new memory stick. tia
    Format it using your PC.
    Quote Originally Posted by rion View Post
    guys,
    we're using micro sd memory cards. 2gb micro sd for my wife's BB pearl and i got the 4gb micro sd/hc (i.e. high capacity) for my BB curve.
    we just loaded them in at ayun, ok naman sila, instantly formatted at hindi nagbago performance kahit pa tinadtad namin ng sounds & video. ako medyo alanganin nung una sa HC version which starts at 4gb, pero ni-research ko naman at compatible siya.
    hth
    Jul 2005
    OT lang po. Can the SE K750i handle a 2 GIG Memory Stick Pro Duo? Medyo old model na yong phone so not sure...
Memory Stick Micro (M2) on Phones
