Results 1 to 7 of 7
Threaded View
    24" Samsung 245B
    24" Wide
    Resolution 1920 x 1200
    Brightness 400cd/m²
    Contrast Ratio 1,000:1 (DC 3,000:1)
    Response time 5ms
    Viewing Angle(Horizontal/Vertical) 160º/160º
    Colour Supported 16.7M
    Signal Input Video Signal Analog RGB, DVI
    Sync. Signal Separate H/V, Composite H/V, SOG
    Connector D-sub, DVI-D
    Power Power Consumption 100W
    Type Built-in
    Features Plug & Play DDC 2B
    Multimedia Speakers No
    Special Features PC : Analog, Digital, MagicColor, MagicBright3, Power built-in Narrow Bezel Mechanical S/W DVI (HDCP), Option speaker
    USB powered hub option No
    Mac compatibility Yes
    Wall-Mount VESA 200mm x 100mm
    TCO TCO03 (Non glossy)
    Cabinet Colour High Glossy Black/ Black
    or
    32" Viewsonic N3240wb
    Size 32 "
    Optimum Resolution 1366x768
    Display Area 708.954(H) X 398.592(V)mm
    Brightness 500 nits
    Contrast Ratio 1200:1
    Viewing Angle 176° horizontal, 176° vertical
    Response Time 8ms
    Aspect Ratio Wide Screen, 16:9
    Glass Surface Anti-glare
    Tuner PAL
    Nicam Yes
    Teletext Yes
    Video Input SCART SCART 1: Composite + Audio
    SCART 2: S-video + Audio
    2 SCART to Composite adapters included
    Component X1 set RCA, YPbPr/YCbCr
    Composite X1 RCA Composite
    S-video inpyt X1
    D-Sub input (PC) X1
    HDMI X1
    PC Audio X1
    Headphone X1
    Audio Output Audio output X1 R/L audio
    Speakers 10W X 2 with SRS WOW 3D surround
    Compatibility PC PC Compatible up to 1360X768 / 1366X768 preferred
    Controls Basic MENU, CH-, HC+, POWER, VOL-, VOL+, SOURCE
    OnView Picture: Preset,contrast,brigtness, colour, sharpness, tint , reset
    Sound: Blance, base, treble, SRS WOW, Reset OSD, Language, Timers, reset to default
    Power Voltage AC 100-240VAC, 60/50Hz (Universal)
    Consumption 180W (Max)
    >>>currently im using 22" Viewsonic..is 32" big enough for PC?..
24" or 32" LCD?
