Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    How can I measure the water pressure of water coming out of the windshield washer nozzle of my car. Or at least the water pressure on the rubber hose that leads to it.
    I need a practical and inexpensive method sana. No experience with this thing. Thank you.
    I assume you are going to measure static pressure?
    Simplest is to see how high the water goes up in the hose. But you will need to extend the hose by a longer length. The hose must be vertically installed.
    Basically this will give you a measure of the pressure head. You can directly measure in inches, feet, yards, cm, meters, cubits, etc.
    With the water pump running, see how high the water reaches until it stops by it's own weight. And then measure the vertical rise from the level of the pump to the point where the water stops rising in the tube.
    I need to measure line pressure as the thing is squirting full blast. When I pull back on the washer switch, I need to see how much pressure the washer pump will be making to drive the water.
    Are we talking about the same thing? Sorry, I really suck at math.
    yup, we are talking about the same thing.
    we are talking about water pressure in a pipe. That can be measured as "head" or how high it can go up vertically
    The higher the pressure, the higher in the pipe it will go before it stops.
    It is the same way measured for water pumps used in fish tanks and water pond decor pumps as well as water pumps fpr home or commercial use.
    I would suggest as a rule of thumb to remember that one atmosphere (14.7 psi) is capable of shooting water upwards to 34 feet.
    So every psi that a pump would produce will shoot water 2.31 feet upwards (nearly 28 inches).
    Sep 2004
    sir ghosthunter are you a mechanical engineer?
    just follow ghosthunters instructions. and if you want the near accurate pressure, you must also deduct to the "head" the normal level (inch,cm,mm) of the water/washer in the reservoir with bottom of the reservoir as the datum.
    just use one of the below formulas to convert "head" to pressure.
    p = 0.434 X h X SG
    where
    p = pressure (psi)
    h = head (ft)
    SG = specific gravity (1 for water)
    or
    p = 0.0981 X h X SG
    where
    h = head (m)
    p = pressure (bar)
    or
    p = 0.1 X h X SG
    where
    h = head (m)
    p = pressure (kg/cm2)
    Feb 2010
    *Doc, para saan po eto? sowi nahilo na po ako sa formula hehehehe!
    Quote Originally Posted by normanenoza View Post
    yes.
    I got dizzy also. hehehe.
    Wala bang gauge na pwede na lang ikabit?
    Now I'm pretty sure I don't regret taking up engineering.
    It's just for one of our office stuff.
    Zero "gauge pressure" ang masusukat nyo kung hayaan lang bumuga yung tubig sa noozle. Kailangan takpan yung noozle at paandarin yung pump para makita yung pressure, at ang pressure reading ay lalabas na tugma dun sa formula kapag sinukat nyo lamang yung height ng buga kapag bukas ang noozle.
    Lalo yata nakalito usapan.
    Ibig sabihin, sukatin nyo na lamang ang height (h, in feet) nung buga ng tubig. Gamitin ang formula ni norman ( p = 0.434 X h) para makuha yung pressure (in psi).
    Ngayon, kung mayroon na kayong pressure gauge na nakakabit sa noozle, makakasukat lamang ito ng pressure kung sarado ang noozle at paandarin ang pump, at ang lalabas na reading ay yung resulta ng formula. Kapag binuksan ang noozle at hayaan sumirit ang tubig, ang lalabas na reading ng pressure gauge ay zero.
    Sana malinaw na yan.
    [SIZE="1"]pero palagay ko lito pa rin lols[/SIZE]
    OT: By now, OTEP is for sure NOT going to have his kids to take up engineering in college as well, just to make sure he won't get this discussion again in the future.
    Quote Originally Posted by kinyo View Post
    Adding more confusion to OTEP, adding a nozzle to the end of the hose to increase the flow velocity of the water will result in a pressure increase in the hose from zero psi.
    Of course, the hose internal pressure will greatly depend on the input flow & pressure rates and the relative change in hose size and output nozzle size.
    My nose is bleeding. hahaha. I just want to know the water pressure because the force of the water coming out will be aimed towards a sensitive membrane thingie and I can't have excess pressure on it.
    Maybe I'll make my future kids take up engineering or math so I don't have to think of it anymore. hahahaha.
    What you are more concerned on is the water velocity, not really about the pressure of the water in the hose.
    Then maybe you should carefully shape the water stream. For the same velocity, smaller water droplet size will carry less kinetic energy.
    This is why a water balloon thrown at a person can hurt and the same amount of water in a spray will just make that same person wet.
    Change the water stream to a mist or fine spray if you need to be gentle.
    Water atomizers are best but can get clogged if any debris finds their way to the nozzle heads.
    forcep lang pala kailangan mo doc otep ... ipitin mo lang yung hose kapag sobra buga ng tubig ... konting diskarte lang sa pag-ipit para hindi naman magsarado yung hose
    pucha! i-lock niyo na itong thread.
    Geek talk is ***y.
    wahahaha. pinipilit ko din intindihin pero lalo ako nahihilo. hahah
    Quote Originally Posted by flakez View Post
    nothing that a few years in engineering college wouldn't fix.
Measuring Water Pressure
