Results 1 to 10 of 46
- Oct 2008
- 380
April 5th, 2010 07:49 PM #1is it safe to use a laptop w/o battery? i'll just connect it to the power outlet?
the laptop is just being used here at home, and hardly taken out.
April 5th, 2010 08:25 PM #2
yeah as per vendors advice it is definitely useful to use your laptop w/o battery... this is because if you use the laptop with battery it will automatically charge it, once such is fully charge you cannot pull it out from the laptop while it is running and eventually your battery will be over charged. so better use your laptop without battery to prolong your batteries life. it is useful for emergency purposes only so better take care of your OEM battery. hehehehe
April 5th, 2010 10:31 PM #3
JUST make sure that the power cord is plugged in to a UPS so you can still power down your laptop safely if a power outage strikes.
- Nov 2009
- 3,484
April 5th, 2010 11:10 PM #4^^+111
Commercial power is notorious for fluctuation and voltage sag that can surely damage your HDD.
You can leave your charger and batteries connected indefinitely without damaging batteries because modern electronics have tickle/float-charge mechanism. Its a myth nowdays that batteries overcharge.
Truth is, repeated discharge and charge cycle and reaching full discharge state wears battery faster, than leaving your batteries connected to AC.
April 6th, 2010 12:29 AM #5
All laptops have circuitry built-in to prevent overcharging. It's actually the heat generated by the laptop that's responsible in reducing the life of the battery.
If your laptop is used inside an airconditioned room or if you're using a proper laptop cooling pad, you can leave the battery inserted. This will help prevent data loss in case of a power failure.
April 6th, 2010 02:24 AM #6
calibrate yung battery also from time to time, this is available on the bios option, to optimize battery performance in the long run.
April 6th, 2010 08:55 AM #7
It is safe to use the laptop/notebook PC without the battery attached if you just always use it connected to the AC outlet.
You can use a UPS to give your laptop the same power protection as having its battery still attached.
A UPS is much cheaper (you can buy one just over P1k in price) than a replacement battery for your laptop. Typically a six-cell laptop battery would cost P5K and up.
- Oct 2008
- 380
- Jun 2008
- 1,741
April 13th, 2010 03:04 PM #9This statement might be true but I will not trust.
The battery of my 6-mos old brand new acquired acer was damaged after 2-mos all time plugged on ac power with battery connected (was used for ******* files download/seed days and nites, 24/7). I learned my lesson so now I remove the battery if use at home using ac power connection. I use the battery twice a week just to fully discharge then recharge to keep it at top condition.
- Oct 2008
- 380
Hello, JUst to check kung paano ni remove "EVEREST" emblem sa hood ? or meron ba auto detailing...
2023 Ford Everest Owners Thread
