Quote Originally Posted by hotwheels View Post
use the battery the way you used your cellphone and charge it once the low bat shows.
madalas kasi laging kasaksak sa on line power pag nasa office tayo. this is one cause to disharged and shorten the battery life.
suggestion,if you are using on line power and laptop showed the battery is fully charged, try disconnect battery while using on line power.
Do you mean remove the battery from the laptop?
