Saan nakakabili ng laptop battery sa Pinas? Model ay HP Compaq NX6125.
bought laptop in Canada. Saw same model sa website www.laptopking.com.ph I think this store is owned by PC Corner.
try mo muna contact ang HP Philippines kung may replacement battery sila. I doubt kung may orig kang mabibili sa mga shops.
OR better yet, try ebay (mahal nga lang) kasi international shipping pa.
kung wala ka talaga mahanap...i noticed on Jack TV a running ad about some shop doing laptop battery repacking. Laptop King ata or something. Basically they'll make a new battery for you. Forgot the url, google mo na lang and see what turns up.
there's also this shop at GSC-Shoppesville Plus named Battery King; not sure if they do laptop batteries per se, pero me nakita ako dati na nagpapagawa ng custom battery sa technician nila.
Post ako uli when i see the ad again...
there's a battery specialist store in g. puyat st. (formerly raon) cor florentino torres in sta cruz manila, they do customize packaging of batteries for laptops and notebook PCs, you might wanna try to check it out there... they also sell hard to find batteries din eh. One time may hinahanap akong battery, wherein lahat ng SM pinuntahan ko, battery shops pati, wala akong makita, pero here, mention it, meron sila lahat... even mga battery for wireless phones na binili nyo sa ibang bansa pwede rin nila customize...
Was surfing and found the battery I was looking for. Its the extended battery for my lappy. Used in conjuction with my current battery, I should have around 8 hours battery life. Additional 1lb weight. Its about $100 shipped to my brother sa US. He's coming home next month. Sulit kaya?
nakakita na din ako nag open ng battery ng laptop
kaya DIY ito ,basta may gamit ka at may pamalit ka ng battery sa loob which same size of Double A batt,and write down the wiring connections
di ko lang din nailista ang spec ng double size battery .kung may dead battery kayo ng laptop try nyo open na hindi mababasag at kunin spec ng battery
pag bago ang laptop battery ,24 hours full charge ba dapat ito?
8 cell. model is pb993a interchangable with pb993ut. I think its the same battery with different model numbers.
price is reasonable naman, batteries for non-branded units costs around 4 thousand na rin eh
what's the usual battery life of an ordinary laptop bat? would it last a year or 2?
it would go around 2 or 3 years under normal use... the most i've experienced is 4 years...
Sir tanong ko lang pano ba alaagaan ang battery ng laptop para di agad masira kasi yung akin wala pang 1 year mula nung binili yung laptop di na nagchacharge yung batt kokaya lagi na lang nakasaksak pag ginagamit ko di ko tuloy maenjoy pagiging laptop nito. thanks po
sa market market at festival mall may nag rerepack daw ng battery
di ko lang alam kung magkano,mapasyalan nga pag nag loko na ang Batt ko
Less than 1 year baka naka warranty pa yan. Check mo sa binilihan mo. Kung wala na sa warranty, try mo www.inkplaza.com.ph they repack laptop batteries.
here's a good additional read regarding laptop batteries...just came across this kanina:
http://www.mobilityguru.com/2006/11/..._they_blow_up/
use the battery the way you used your cellphone and charge it once the low bat shows.
madalas kasi laging kasaksak sa on line power pag nasa office tayo. this is one cause to disharged and shorten the battery life.
suggestion,if you are using on line power and laptop showed the battery is fully charged, try disconnect battery while using on line power.
