Results 1 to 10 of 21
March 30th, 2005 04:21 PM #1
I remember there was a code dialled wherein calls/text can be prevented nor send. what are those codes again. I remember having tested it to both Globe and Smart.
March 30th, 2005 04:43 PM #3
yup but that will work only with voice calls. What i am looking is yung pwede pati sa sms. got it dati sa ebnc. . . sayang
tnx anyway
March 30th, 2005 04:50 PM #4
As mazdamazda said, you can find it in your phone's menu, under the Security settings (for Nokia models).
It has the option to block voice calls, SMS and asynchronous data services. I'm pretty sure that it works for SMS, because I once tried sending a text message to myself with the barring activated for incoming calls, and failed to receive any.Last edited by Bogeyman; March 30th, 2005 at 04:54 PM.
March 30th, 2005 05:28 PM #6
sorry eto pala:
*33*1234# send - lock
#33#1234# send -unlock
na lock call at text nyan
March 30th, 2005 05:34 PM #7
Perhaps you can execute it but still it depends on your Network provider if they allows you to do it. ;)
March 30th, 2005 05:38 PM #8
by barring your incoming and outgoing calls, it will also bar your incoming and outgoing text. it works the same. now if you want to bar only your outgoing text, this is what you do. now it depends on the unit you have. there are some phones that have an option to send sms thru "GSM" or "GPRS", if you chose GPRS, you won't be allowed to send text at all, but your outgoing call wont be affected.
March 30th, 2005 05:40 PM #9
Originally Posted by ron
March 30th, 2005 05:42 PM #10
Bar all outgoing calls * 33 * Barring Code # SEND
to cancel the barring of outgoing calls # 33 * Barring Code # SEND
Bar all incoming calls * 35 * Barring Code # SEND
to cancel the barring of incoming calls # 35 * Barring Code # SEND
Bar all outgoing international calls * 331 * Barring Code # SEND
to cancel the barring of outgoing int'l calls # 331 * Barring Code # SEND
all of these codes are generic codes. it depends on your unit model and brand
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
