Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    I bought a new HP 8gb flash drive. I tried to install password protection (MasterVoyager), but something went wrong while installing. Now it's write protected. I can't format it because it's write protected. Tried low level formatting, but always get some error messages.
    Can I still save my USB flash drive?
    You could try using with Windows auto-run disabled.
    The encryption system automatically runs when you plug-in the USB drive. Since the software is active, it may prevent formating of the USB drive.
    Disabling auto-run would prevent the software from launching and hopefully give you access to your USB drive, including formatting it.
    What's the simplest way to disable auto-run for external devices?
    I only got to disable my cd-rom
    Mar 2004
    You may also want to try mounting the thumbdrive to a foreign OS like Linux or Mac.
    If the software protection does not kick in, you should be able to format.
    How to do that?
    Jan 2010
    Some thumbdrives come with their own proprietary formatting software. You may have a copy of that, or if not, a copy may possibly be download from the manufacturer's site.
    Tried everything, still can't format the flash drive. It always says disk is write protected
    Say bye bye to it and visit your nearest CDR-KING branch for a replacement USB flash drive. They even have 32gb flash drives...
    If you're comfortable with linux and you have access to a linux box try this:
    try plugging it in a linux box, see if it will detect it, if it does, do an fdisk -l to check if it's either /dev/sda, /dev/sdb, etc. etc. once you've found out which device represents your flash drive, do an fdisk on it to totally erase it.
    Note: you have to do this as "root" (obviously) and if the flash drive auto-mounted when you plug it in, unmount it first before doing an fdisk on it.
How to recover my USB flash drive?
