Results 1 to 10 of 14
April 23rd, 2010 03:09 PM #1
I bought a new HP 8gb flash drive. I tried to install password protection (MasterVoyager), but something went wrong while installing. Now it's write protected. I can't format it because it's write protected. Tried low level formatting, but always get some error messages.
Can I still save my USB flash drive?
April 28th, 2010 02:17 AM #2
You could try using with Windows auto-run disabled.
The encryption system automatically runs when you plug-in the USB drive. Since the software is active, it may prevent formating of the USB drive.
Disabling auto-run would prevent the software from launching and hopefully give you access to your USB drive, including formatting it.
April 28th, 2010 11:47 AM #3
What's the simplest way to disable auto-run for external devices?
I only got to disable my cd-rom
Tsikot Member Rank 3
- Mar 2004
- 2,053
April 28th, 2010 11:49 AM #4You may also want to try mounting the thumbdrive to a foreign OS like Linux or Mac.
If the software protection does not kick in, you should be able to format.
April 28th, 2010 12:03 PM #6
April 28th, 2010 12:04 PM #7
Some thumbdrives come with their own proprietary formatting software. You may have a copy of that, or if not, a copy may possibly be download from the manufacturer's site.
May 7th, 2010 04:26 PM #8
Tried everything, still can't format the flash drive. It always says disk is write protected
May 7th, 2010 04:35 PM #9
Say bye bye to it and visit your nearest CDR-KING branch for a replacement USB flash drive. They even have 32gb flash drives...
May 7th, 2010 04:38 PM #10
If you're comfortable with linux and you have access to a linux box try this:
try plugging it in a linux box, see if it will detect it, if it does, do an fdisk -l to check if it's either /dev/sda, /dev/sdb, etc. etc. once you've found out which device represents your flash drive, do an fdisk on it to totally erase it.
Note: you have to do this as "root" (obviously) and if the flash drive auto-mounted when you plug it in, unmount it first before doing an fdisk on it.
Hmmm.... Kailangan na ng aircon service niyan innova mo. I have a blackish red innova. Bilad sa...
