Results 1 to 10 of 14
April 23rd, 2010 03:09 PM #1
I bought a new HP 8gb flash drive. I tried to install password protection (MasterVoyager), but something went wrong while installing. Now it's write protected. I can't format it because it's write protected. Tried low level formatting, but always get some error messages.
Can I still save my USB flash drive?
April 28th, 2010 02:17 AM #2
You could try using with Windows auto-run disabled.
The encryption system automatically runs when you plug-in the USB drive. Since the software is active, it may prevent formating of the USB drive.
Disabling auto-run would prevent the software from launching and hopefully give you access to your USB drive, including formatting it.
April 28th, 2010 11:47 AM #3
What's the simplest way to disable auto-run for external devices?
I only got to disable my cd-rom
Tsikot Member Rank 3
- Mar 2004
- 2,053
April 28th, 2010 11:49 AM #4You may also want to try mounting the thumbdrive to a foreign OS like Linux or Mac.
If the software protection does not kick in, you should be able to format.
April 28th, 2010 12:03 PM #6
April 28th, 2010 12:04 PM #7
Some thumbdrives come with their own proprietary formatting software. You may have a copy of that, or if not, a copy may possibly be download from the manufacturer's site.
May 7th, 2010 04:26 PM #8
Tried everything, still can't format the flash drive. It always says disk is write protected
May 7th, 2010 04:35 PM #9
Say bye bye to it and visit your nearest CDR-KING branch for a replacement USB flash drive. They even have 32gb flash drives...
May 7th, 2010 04:38 PM #10
If you're comfortable with linux and you have access to a linux box try this:
try plugging it in a linux box, see if it will detect it, if it does, do an fdisk -l to check if it's either /dev/sda, /dev/sdb, etc. etc. once you've found out which device represents your flash drive, do an fdisk on it to totally erase it.
Note: you have to do this as "root" (obviously) and if the flash drive auto-mounted when you plug it in, unmount it first before doing an fdisk on it.
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
