Results 871 to 880 of 1094
turbo
- Nov 2002
- 503
September 17th, 2007 10:20 AM #871Sorry for the bother but I am an old man and don't know how to post pics in this forum.
I will just give the address. I hope you can visit it.
http://www.flickr.com/photos/81856035*N00/1393019263/
http://www.flickr.com/photos/81856035*N00/1393016871/
http://www.flickr.com/photos/81856035*N00/1393909092/
http://www.flickr.com/photos/81856035*N00/1393907022/
http://www.flickr.com/photos/81856035*N00/1393009809/
http://www.flickr.com/photos/81856035*N00/1393007585/
http://www.flickr.com/photos/81856035*N00/1393899600/
http://www.flickr.com/photos/81856035*N00/1393897366/
BANNED BANNED BANNED
- 3,790
September 17th, 2007 05:17 PM #872my concern is the terminology of "optimzed for video" - Did your electronic supplier explain what technique was applied in those cables to make it optimized for video?
Kasi afaik, the signal passing these cables are still analogue or electric pulse/wave. as such, the only thing the will "disrupt" that electrical signal is emf and/or resistance. long or wrong type of wire/cable will work like a resistor - thus the resistance.
electrical interference is also greatly reduced by using coaxial configuration - main line on the center and the ground line is "coating" it. this is why antenna wires and speaker cables uses coaxial type of cables.
bottomline, TECHNICALLY there is no difference between a regular RCA cable with those branded COMPONENT cables because both are coaxial-type of cables.
BUT those are just my technical self-learned deduction. I have YET to know the "truth" behind the word "optimized for video" ek-ek.
I am thinking that maybe they use "gold-coated" wires and connectors...kasi gold is noted to have better conductor capability than copper or steel. But then again, gold coated connectors and wires are really OVERKILL concept for me.Last edited by wildthing; September 17th, 2007 at 05:26 PM.
September 17th, 2007 05:45 PM #873
Yup, AFAIK, there is no difference between 3-pronged regular RCA cables and component cables, except the color-coding (red white yellow vs. red green blue). The latter is not optimized for video.
I lurk around a lot over at pinoydvd.com (I've been a member since 2004, pero less than 50 posts pa lang ako hehehe), and I've never heard of any manufacturer claiming that component cables are optimized for video. There's basically nothing you can do for component cables that you cannot do for composite.
Tsikot Member Rank 4
- 2,719
September 17th, 2007 06:28 PM #874i would interpret "optimized for video" as having sufficient bandwidth for video signal transmission ... the NTSC composite video signal is normally 6MHz wide and for most RCA cables, even the cheapest ones, can carry the video signal for short lengths
unfortunately, the cheaper RCA cables in the market are not really coaxial, instead the purported "shield" is actually a few strands of wire and helically wrapping the center conductor with lots of unshielded portions ... i believe this kind of cable will degrade the video signal over longer distance (>10 feet) and susceptible to emf interference, which could be the reason why you don't find them longer than a meter or two
however, the RCA cables supplied by manufacturers of known brands are usually true coaxial are can be trusted to provide sufficient bandwidth for video
expensive cables like monster are, imo, simply marketing hype and surely one could find lower cost true coxial cables that could perform just as well
gold connectors? tell that to the marines! they are useful only for semiconductor manufacturing
September 17th, 2007 06:43 PM #875
If anyone is interested in going Tru HD, then composite, s-video and component cables are considered obsolete. The standard connector for HD is HDMI. It's the complete audio-video cable that allows not only HD Video but also HD uncompressed audio.
- 3,790
September 18th, 2007 06:43 AM #876^^ HDMI - eto rin ba yung parang rectangular na plug ng DVI as seen in this picture -
o iba pa yun?
September 18th, 2007 08:57 AM #878
DVI is different from HDMI. The former has 24 pins, while the latter has 19. AFAIK, DVI is also becoming obsolete. Most new video cards in the market now have HDMI ports
September 19th, 2007 12:36 AM #879
buy the monster kung si generic ay maiksi (maiksi = was talking about the length). other than that parehas lang yan.
September 19th, 2007 08:40 AM #880
Konstruksyon ng Metro Manila Subway Project, ininspeksyon ni PBBM PTV Philippines
Metro Manila Subway 2022/2025
