Results 271 to 280 of 1080
- 10,620
January 7th, 2004 03:40 PM #272
Masaya na ako TV kong 21". Actually may HT kami pero di ko alam kung ano ung mga Description nila 41" ata ung TV. Akin ung pinaka-latest ng JVC. Palagi ko ngang kita s newspaper ang HT namin. Pero wala akong paki. Basta malakas ang sounds namin at widescreen, happy na ako. Para di ko na marinig ang mga nag-aaway na kapitbhay. Lalakasan ko n lang volume namin.
- 10,620
January 7th, 2004 04:03 PM #273yup tama ka prometheus, if you're contended with your gears ayos ka na dun. kaya nga let your ears show the way.
different strokes for different folks,
may kilala nga ako up to now naka PRO-LOGIC pa rin, pero contended na .
right now ok na ako sa 2 channel stereo set up ko
- 10,620
January 13th, 2004 03:45 PM #274mazda2, may na isip ako on how to use your monitir audio B2 kahit wala ka pang audio/visual receiver
buy an active subwoofer with speaker output.
connect the audio out of your TV to the subwoofer via Y-connector cable or just use ordinart RCA cable, connect monitor audio to the sub.
bali ibabato ng sub yung high freq sa monitor audio b2 mo(65hz-20Khz).
habang sasaluhin naman niya yung low freq (40hz)
January 14th, 2004 10:34 AM #275
what does progressive scan means? para saan ito at ano nagagawa nito. thanks!
- 10,620
January 14th, 2004 11:01 AM #276Progressive Scanning: Each frame of a video image is scanned complete, from top to bottom, not interlaced. For example, 480p means that each image frame is made of 480 horizontal lines drawn vertically. Computer images are all progressively scanned. Requires more bandwidth (twice as much vertical information) and a faster horizontal scan frequency than interlaced images of the same resolution.
here's a sample of progressive scanned image
(apologies to akyatbundok)
this is actual image from the TV
ang galing ano parang lifelike
January 14th, 2004 12:41 PM #277
wow! ganda at saka ang linaw! pero ang sabi dapat ang TV may progressive scan din. Is this true? at saka not all model have this feature.
Sensya sa mga tanong..newbie po sa mga ganitong bagay.
- 10,620
January 14th, 2004 02:29 PM #278yup dapat may progressive scan din ang TV, medyo hindi pa mainstream dito ngayon yun. but you can try connecting them sa component input (Y, Pr, PB) although this will not guarantee prog scan.
common sa atin ay ang S-video, ako nga hanggang ngayon composite connection lang ako eh pero pewde na.
January 14th, 2004 02:56 PM #279
sir kimpoy, better upgrade kahit s-video connection lang... you'll never look back. hehehe
- 10,620
As of kahapon open pa yung sa SM Makati. Wala ring tao.
National ID Law
