Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 65
    #21
    Quote Originally Posted by beachbum
    anyway kahit idownload mo sya to mpeg2 kaagad you still need to have the same amount of hard disk space as downloading in dv format, kapag sinasave na lang ang file saka sya lumiliit sa size na mpeg2.
    That's true. But take the movie, King Arthur which I recorded from HBO. The whole movie was a 6.5GB mpeg2 file. If I saved it as DV-AVI or uncompressed avi, it would've taken up close to 24GB of hard drive space. It's hard to ignore the space saved. Also, I think if you record mpeg2 in realtime, you don't need to allocate as much hard drive space.
    Add: Ulead DVD MovieFactory 2 has a "Direct to Disc" recording mode where the recorded footage bypasses the hard drive altogether and goes straight to dvd or cd.
    Dec 2003
    #22
    the InnoDV 1000 is just what you need, cheap pci addon card
    #23
    OT: can the discs in DVD-camcorders directly play in DVD players?
    Signature
    #24
    Quote Originally Posted by boybi
    It should. I mean it's not that different from a disc made with a DVD Recorder in that there should be an audio_TS and a video_TS folder in the disc just like a regular dvd.
    Jan 2003
    #25
    question
    iNNo DV1000 ba name nong card? wla ng model ito?
    is this for miniDVS lang or also for old handy cams like video 8s?
    #26
    Quote Originally Posted by buknoy2002
    question
    It's a firewire card. As far as I know the only camcorders with firewire ports are MiniDV camcorders and a few of Sony's Hi-8 camcorders. All the rest, including 8mm, have analog composite in/out.
    Jan 2003
    #27
    thnx juna ka pecto
    so for video 8s, dpat tv tuner card ang bilin ko?
    Oct 2005
    #28
    kahit hindi tv tuner card. video capture card pwede na. unless gusto mong manood ng tv sa pc mo or gusto mo ring irecord ang mga tv show sa pc.
    Oct 2005
    #29
    The DVDs burned in DVD camcorders will play in DVD player that support DVD+/-R,RW. Usually, the supported DVD format ay sinasama na to sa specs ng DVD players.
    This support "officially" came out around 2~3 years ago, when DVD burners came out. "Unofficially", burned DVDs, specially using the +R notation, has been fully supported by DVDs since 2000, lalo na pioneer DVD players. AFAIK, Pioneer DVD players was one of the first DVD players that can read burned "blue" VCDs before DVD burners were around. Sony, Panasonic and high end DVD players (Denon, etc...) was sensitive (or not sensitive?) to this burned DVDs since it usually can not read it.
    question
    Jun mentioned that some Sony Hi-8 videocams had support for digital recording. These were the Sony videocams that came with D8 (digital 8) recording. But to have it digitally recorded, you need to switch on this option so that it will be digitally recorded. Pero pag walang D8 capability or kung meron at hindi naka switch on, you need a capture card just like beacbum mentioned. Not sure though kung meron pang stand alone capture cards nowadays. Kung meron man, check the price and compare it with TV tuner/capture card bundles. Pagmagkalapit ang presyo, get the TV tuner/capture card bundle.
    #30
    thnx juna ka pecto
    Yep. Like what beachbum said, you can use a dedicated video capture card or a tv tuner. I can't vouch for the video quality since I don't have a dedicated video capture card. But, my video cards past and present have had Video In /Video Out (ViVo) which can take both composite and S-Video. I use the ViVo of my video card for capturing shows from DirectTV/analog devices and firewire when capturing from the MiniDV camcorder.
    My Hauppage WinTV PCI tv tuner dates back from 1998. It's too old to capture reliably to mpeg2 at 720x480. But, it still can capture reliably at 640x480 or smaller and capturing uncompressed avi has never been a problem. The quality of captures are inferior to the captures I made with my video card, though.
    If you do get a tv tuner card, get either a Leadtek or ATI. I personally prefer ATI because of the ATI Rage Theater chip used in capturing (also in my video card). I can vouch for the excellent picture quality although it won't capture "protected" media like protected commercial dvd's or vhs (something to keep in mind if you're into that sort of thing).
    I've heard many good things about Leadtek as well although I don't have one so I can't vouch for it.
    #31
    As for video quality, here's a few samples of what you can expect. These are all stills from Divx files that were made from different sources:
    Here's one from MiniDV through firewire. It was actually downsized from 704x480:
    This one was captured fron DirectTV via the ViVo (ATI Rage Theater) of my video card:
    #32
    More samples:
    This one was a conversion of a vhs movie and captured via my Hauppage WinTV tv tuner:
    This one is footage from my 8mm camcorder captured via the ViVo of my video card:
    Jul 2005
    #33
    Quote Originally Posted by 3kster
    Di ba ang south bridge, 133 MB/s lang? Plus taking into account the transcoding into the format you want by the CPU, even using the highest CPU frequency available, you will still be limited by the PCI transfer rate which uses 33MHz. Unless your using PCIe, of which at x1, can handle ~500MB/s. Then again, you will be limited by the HDD transfer rate at around 100~133 MB/s for IDE and SATA at 150 MB/s
    And DV rate is what, like 200MB per MINUTE.
    #34
    Quote Originally Posted by picantorange
    It's very close. Recording DV footage is more or less 12Gb/hr which is ~12288MB/hr, ~205MB/min, or 3.41 MB/sec.
    A pci firewire card should be enough although I still prefer built-in firewire on the motherboard.
    Add: As for firewire cards, I still prefer Maxtor's own firewire card which they recommended for their own external firewire hard drives. Ours have captured flawlessly since we bought it back in 2000.
    Oct 2005
    #35
    corrected yourself there.....this was your previous post, and realtime at 200MBs wold really be "awesome".
    Yep, na-mention na yung firewire and software needed. You'll also need a cavernous drive, since the data rate of DV is about 220 MB/s.
    Just want to add, ATI has an "all-in-wonder card" (AIW) that can cater to both digital and analog in. Nvidia has an equivalent of ATI's AIW cards so does Matrox (its correct, its spelled as Matrox, not Maxtor) Marvel chips but ATIs solution is still the best. ATI's AIW cards are a "PVR/capture card/"graphics card/TV tuner all in one but its pretty expensive and you can only opt for this if you have setup your PC as a multimedia center/HTPC. ATI has other product line up you can choose from aside from their AIW line.
    #36
    You have to remember that the original poster just wants to get footage from MiniDV and possibly 8mm to the computer. An ATI AIW video card as a solution, borders on the extreme especially with price due to features the user may not use. The next best thing would be Video In/Video Out (ViVo) which doesn't add much to the overall price of a video card. The main disadvantage of both is that when it's time to buy a new video card, that's it for them.
    A pci firewire card (for MiniDV) can be carried on to the next computer although most new motherboards have firewire built-in. Same goes for a pci tv tuner card/capture card (for 8mm and other analog sources). My Hauppage WinTV PCI tv tuner card went through 4 pc's and still works fine. Not bad for a $70 initial investment (back in 1998). The same goes for my ($40 back in 2000) Maxtor firewire card which went through those same 4 pc's before I ended up with ViVo video cards and built-in firewire.
    Jul 2005
    #37
    Haha, sorry. I stand corrected - by myself. Yung firewire card ko ewan ko kung anong tatak. Kasama lang nung bumili ako ng miniDV cam.
    OT: Sarap mag-edit! Kakatapos ko lang i-edit yung music video ng mga pinsan ko dito. LOL.
    #38
    use tv video card captured, if your using local pc, but if your have macintosh no need na , dahil built in na yun captured card nila, and after that sabi nila use different software kung ano type mo and kung ano mas mabilis na software.
    #39
    Quote Originally Posted by IIE
    Macs have firewire built in which is fine for a MiniDV camcorder. But, to capture analog video like 8mm, he still needs to buy a separate capture device.
    iMovie HD is normally part of every Mac (like our Mini here). It's decent and easy enough so long as you work with DV files. But start working with analog files or mpeg2, and iMovie HD becomes a pain. What would be effortless with pc video editors like Ulead Video Studio, Vegas, or Pinnacle Studio is very laborous and time consuming with iMovie. An example would be importing different types of video files to iMovie, be ready for a looong wait. In contrast, a video-editing app like Ulead Video Studio will import those same files almost instantaneously.
    If the original poster will work exclusively with DV files, then, a Mac with iMovie would be fine. But, if he's going to work with both DV, mpeg2, avi, etc, it's best to do video-editing on the pc.
    I rarely use iMovie HD on the Mac. But, I do make heavy use of iPhoto. iPhoto is awesome for making video clips of picture slideshows. Whenever I have to include slideshows of photos in my homemade dvd's, I normally make the QT file in the Mini with iPhoto, burn it to cd with Toast, then import it to my pc and dropping the file into the timeline of the pc video editor.
    Oct 2005
    #40
    Jun, just some questions, i know majority of us have multisytem TVs, but on my editing software, theres a selection on what system to encode, so what system do you usually use? Correct me if i'm wrong, but one system has better refresh rate and another has higher resolution? Which would be good for DVD playback? can i pick both?
    Picanto-range, my firewire card also came with my videocam, but latest DV videocams right now don't bundle this, so I guess swerte tayo. That stayed with my old pc and my latest pc has a built in one. Regarding editing, he-he-he, sarap panoorin ng pinag hirapan, i usually send copies to my relatives just to show off what I've done, tapos yung content, eh secondary na lang
Help: Transfer videocam-minidv to pc
