Results 1 to 10 of 11
September 21st, 2008 06:11 PM #1
bakit ganun basta may hawakan me na metallic part sa pc ko nagagaround ako. pati flash drive di ko maisaksak ng walang sapin na tela. ano po gawain para maalis ground. tnx
September 21st, 2008 06:45 PM #2
tinanggal mo ba yung parang etits sa powercord nya? grounding kasi yun eh.
kung tinanggal mo, try to get a new powercord na may etits.
September 21st, 2008 06:49 PM #3
ganyan din sakin minsan. subukan mong lagyan ng insulator don sa may screw ng motherboard and casing. tape or anything para lang walang direct contact. saka linisin mo na rin maigi yung loob. minsan dahil din sa mga alikabok eh. heheh.
September 21st, 2008 08:24 PM #4
September 21st, 2008 08:31 PM #5
September 22nd, 2008 09:47 AM #7
Something in your power supply may be causing it. Your chassis should have no voltage (potential) on it. The ground line on your power cable is useless if your power source has no grounding line....
6707:choir:
- Sep 2008
- 631
September 22nd, 2008 10:17 AM #8[SIZE=3]Sir[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]What you are experiencing is static electricity. [/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]To remove that you must bond your self to the equipment.[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]Try to browse the web for the solution.[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]Thanks[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]my email is bmacavanza*gmail.com[/SIZE]
September 22nd, 2008 01:19 PM #9
usually, it's the power supply that is grounded. your printer, soundsystem, etc will be grounded when touched in the metallic area too. it can be alternatively remedied with adding ground from your pc casing to the dirt. however, if you touch the casing this time, there is a feel of electromagnetic in the casing. but it doesn't give the bee sting anymore.
BANNED BANNED BANNED
- Aug 2008
- 1,099
Automatic po Sir
