Results 21 to 30 of 35
February 22nd, 2008 04:01 PM #21
patanong na rin po. if i want a non-powered(thru a separate adaptor) external harddisk, para saksak na lang ng saksak sa USB port, i will buy the 2.5" kind. tama ba?
up to how many gigs ba kaya ng 2.5", na hindi sya mag-require ng separate power adaptor?
speaking of FAT32 formatting, gaano max size na kaya nya i-handle or size limitation?
February 22nd, 2008 05:52 PM #22
Ummm. Yeah. A non-powered hard drive is almost always 2.5" or smaller. I assembled one together where it has 2 usb connectors just in case the power from 1 usb port isn't enough.
I'm not sure what's the biggest capacity 2.5" drive. But, the eSATA 2.5" hard drive in my Toshiba laptop is 250gb.
As for FAT32, I'm also not sure if Windows can handle it. I'm not about to test it on any of my hard drives. I think it can, though. Maybe someone can shed more light.
But, even if Windows can't, most hard drives come with formatting utilities that allow it to go past the normal size limit. I mean my 500gb WD My Book is FAT32.
DIY to death!
- Jan 2003
- 451
February 22nd, 2008 07:13 PM #23Wikipedia says FAT32 can handle volumes of up to 8Tb. That's 2^40 bytes.
Although that's probably large enough for most of us, there's another limit that we're more likely to bump into and that's the maximum file size. A single file on a FAT-based drive can only be up to 4Gb in size. Something to consider if you have a lot of DVD ISO's you want to copy over.
Windows, starting with 2000, was "crippled" as far as creation of FAT32 drives go. Win2K won't let you create a large enough FAT32 partition, forgot how large, 32Gb yata. XP doesn't even have that option anymore. MS wants everyone to go NTFS. :bleh: That's why I still have a Win98 boot disk.
February 22nd, 2008 08:29 PM #24
DIY to death!
- Jan 2003
- 451
February 22nd, 2008 09:29 PM #25
February 22nd, 2008 09:46 PM #26
For now, I can say exFAT sucks. XP SP2 won't even recognize the format asking if I want to have the drive formatted. Now reformatting to FAT32 via XP Home.
February 22nd, 2008 10:37 PM #27
dito, wd 250gb external hdd nasa 205 sgd. pwede na, balak ko bumili
February 22nd, 2008 11:25 PM #29
Anyway, I found out a few things. If the hard drive is already FAT32, leave it alone.
If by chance you need to reformat, don't use Windows Format, be it the desktop utility or via the Command Prompt. Use the Utilities that came with the hard drive such as WD Lifeguard Data Tools because it supports the size of the disk plus it's a heck of a lot quicker to finish.
- Jan 2006
- 191
February 23rd, 2008 11:27 PM #30
high idle RPM at engine start
