Results 11 to 20 of 25
March 24th, 2006 03:43 PM #11
if your PC has built-in firewire port, you'll only need to buy a fireware cable (around P 125-150 lang sa Compex, but you have to check kung 4-pin or 6-pin yun ports ng videocam and pc mo. 2 types of cables kasi.
meron din nabibili cheap video capture card yun innodv sa gilmore kung wala built-in firewire port. my pc has generic capture card built-in sa board nya kaya cable na lang binili ko last month.
capture is a breeze if you'll use Adobe Premiere. others kasi parang hindi ok capture quality like Windvd or Windows Movie Maker.
March 24th, 2006 04:59 PM #12Originally Posted by happy_gilmore
You can transfer your video to PC by using a TV tuner card. You can just do a playback from the DV camera to the TV tuner's video-in port. The tv tuner software will just record to a video file on the PC. Not the highest quality but it will work. Then just burn the video file to your CD Writer using NERO.
March 24th, 2006 07:02 PM #13
Most MiniDV cameras have a 4-pin firewire port. It might be a good idea to have 2 types of firewire cables: a 4-pin to 4-pin for laptops and a 4-pin to 6-pin for desktops.
You can use MovieMaker 2 to capture uncompressed avi or DV-AVI. Bear in mind that an hour of footage can take more or less around 12 gb.
I prefer to use 3rd party software such as Pinnacle Studio or Ulead Video Studio and do an on-the-fly conversion to mpeg2 instead of DV-AVI. Smart-rendering built-in to at least Ulead Video Studio (not sure about Pinnacle Studio) should keep degradation to a minimum by avoiding repeated re-renders.
- Nov 2002
- 67
March 24th, 2006 08:46 PM #14Pinnacle video studio 9 ang gamit ko. I suggest na wag mo ilalagay sa long play ang recording mo, nabawasan kasi ang picture quality.
March 24th, 2006 09:09 PM #15
Another option to consider is a standalone DVD recorder if all you want is to watch your video as a DVD or VCD without any fancy menus. A DVD recorder will give you the absolute best picture quality without the hassles of capturing and rendering in a pc. Even VCD mode (6 hrs in a DVD platter) has more than acceptable quality. Just make sure the DVD recorder has a firewire port.
- Jul 2004
- 167
March 24th, 2006 10:24 PM #16Ito sir ginamit ko before, siguradong di ka papalya dito:
1) Ulead Video Studio (yon copy ko dati kasama nung binili ko yong firewire card ko)
ito yong gagamitin mong pang capture at pang edit. super dali to gamitin pang
novice talaga. So .AVI bale yong output nito galing sa pc mo.
TIP: Minsan, medyo cut mo din yong pag capture mo kasi medyo mahirap mag
convert sa MPEG pag sobrang laki nung file. Ako usually, cut ko every 20 mins.
Pag mas sanay ka na pwede ka nang mag upgrade sa Media Studio (ulead din to)
mas advance yong effects at mga style na pwede mong gamitin.
2) Once na meron ka nang .AVI files. Gamitin mo yong TEMPGENC na pang convert to
VCD. Freeware ito. Meron kang trial period na 30 days to create you video in
SVCD format pero after 30 days VCD na lang. So it this point meron ka nang
*.MPEG files.
3) Gamit ka nang VCDeasy para ma-write mo yong videos mo sa CD at mapapanood mo na sa ordinary player. Freeware din pala ito.
The best yong quality nung TEMPGENC at VCDeasy as far as freewares are concern.
For more info you can check this site. Dami kang matutunan dito concerning video editing:
http://www.videohelp.com/
- Jul 2004
- 167
March 24th, 2006 10:29 PM #17.. pag medyo tinatamad ka naman, bili ka na lang nung dvd recorder.. mura na lang ngayon yon eh. meron nang nabibili sa singapore na mga 300 to 500 sing dollar. meron pa nga ako nakita na 200 sing dollars nung isang araw kasi di nga lang known yong brand. Cguro sa pinas baka halos ganun na din price nyan... 9500 to 15000 php
SiRaNeko
- Jan 2003
- 973
March 25th, 2006 01:50 PM #18yung mga dvd recorder e may usb port din?
usb yung mini dv camera ko e
- 10,620
March 25th, 2006 04:36 PM #20panasonic din ang videocam ko...
thanks sa mga tips ninyo mga fafas...
pero bakit yung videocam ko walang videocam to PC cable? may nabibili bang separate nun?
sa akin lang naman para malipat sa PC tapos i burn sa CD
Monk-owned R53
