Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 59
    Jan 2009
    what did you do, when you 'hacked" into it?
    i see the additional hot and cold box additions...
    Made it a bit "smarter". It's both for convenience and to lower the power consumption.
    Here are a few examples:
    1. I can ask Alexa to turn on/off the Hot water or Cold water, independently. Or I can say "water dispenser" instead and it turns on/off both hot and cold simultaneously.
    2. I have setup elaborate timers for when the Hot and Cold water turns on. For example, the Hot water automatically turns on 30 minutes before our alarm goes off and turns off around an hour later, typically after we've drank our hot beverages. As for the Cold side, nobody drinks cold water early in the morning so I set it to turn on at 7am. I have subtle schedule differences during certain weekdays and weekends.
    3. If I say "Alexa, coffee mode", it will turn on the hot water for 30 minutes then shut off. Alexa would remind me when the water is ready and when it's about to turn it off again.
    4. It's also part of a routine called vacation mode. When I trigger that via Alexa, it turns off everything in the house.... lights, power plugs, A/C, entertainment center, water dispenser, etc.
    5. Finally, whatever state it is in, both cold and hot water are set to shut off every night at 9:30pm
    I was thinking between Top load and Bottom load, but reading on the old threads, I decided that bottom load is the better option.
    BUT now I can't choose if I should get the button or push option? The one where you push to get the water is easier to replace but it's doesn't have a pump like the button option for fast dispensing. My problem with the button is you have to look pa where to properly place the cup/glass, pwede ka pa mapaso unlike the one where you push?
    Jan 2009
    Both models should have pumps.... and it says so in the description. How else will water go from the bottom compartment to your glass?
    I missed that I mean I assume the black one has a more efficient pump (this is the same dispenser they have at the hospital and it was surprisingly mabilis) But is it worth the price difference?
    Jan 2016
    7 years na pala last January ang unit namin and still good except for the occasional drip sa hot water dispenser, so may sahod lang na baso
    Wala pa ung white option dati otherwise we would have gotten that because cheapest was out option back then. 11k ata ang other option but I can't remember the brand na.
    Ang puna ko lang sa white ay kung matibay ba ang lever vs push button sa black. but para sa akin, mas convenient ang button kasi you just place the glass below and use a finger to press the button, sa white you have to hold the cup and exert more effort pushing it forward.
    Yun din iniisip ko kung ano ba mas durable, yung lever kasi nabasa ko dito madali palitan, ewan ko lang sa button.
    Same pala tayo ng choice sa black? Nagmahal pa pala instead of getting cheaper
    Jan 2009
    The main difference I think is that the more expensive one (the black unit) has three taps; hot, warm and cold. The other has only hot and cold. Design choice is subjective, so get one that will go well with your interior design.
    As for the tap design (push-button or lever action), as long as they have local support, you'll be fine. Also, if it's for home or personal use, the taps should last a very long time. I'd be more worried about the pump giving out.
    Our Camel water dispenser is 9 years old. No repairs yet but the plastic panels which were originally white, have aged into a shade of beige.... which is fine because our walls are painted yellow. lol
    Jan 2016
    Sale lang katapat nyan para mag mura
    go to shoo mart and see what replacement dispenser taps they have.
    buy the unit that has easy-to-source replacement parts.
    Nov 2019
    Akala ko not needed pa i plug to AC outlet yung bottom load para makapag dispense, needed pala.
    Wala paba sa market na bottomload dispenser model na no need i plug sa AC outlet?
Durable Brand of Water Dispenser/Cooler
