Results 1 to 20 of 20
    Jul 2003
    Anybody used this device as seen on TV. Totoo kaya eto Php 2,680 lang ang presyo. Bibili sana ako kung totoo eto. Ang laki ng matitipid 30% daw according to the ads.
    "Here is a smart way to save up to 30% of your electrical bill. This new generation device can filter the supply voltage while improving the efficiency and power factor of your electricity consumed.
    This Power Energy Saver can potentially save up to 30% off your electricity bills simply by improving the efficiency and power factor of electrical appliances. The device is able to store electricity for 5 to 10 seconds and release it for use during the downside supply. It can also improve safety by reducing the overheating of electrical wiring, hence reducing the size of wiring and copper loss.
    One unit of this device will work on the whole circuit in your house as soon as you turn it on. Our field testing for most homes have consistently shown that one unit of the Power Saver will save 3 to 4 Kwh per day, based on electrical consumption of 30 Kwh per day. The amount of savings depends on few factors, such as the type of electrical appliance use and the amount of electricity use.
    In addition to extending the life span of appliance motor, this device also reduces the reactive power generated by inductive loads, It helps the utility companies by eliminating interference to the power supply.
    Suitable Enviroment : Shop, home, restaurants, office, school etc.
    Power Test by Manufacturer
    Before Installation of 'Big Power" 1P30 Energy Saver (Measured Values) After Installation of 'Big Power' 1P30 Energy Saver (Measured Values)
    IL (A) Power Factor Real Power (W) Is (A) Power Factor Real Power (W)
    1.108 0.545 138.8 2.254 0.270 140.0
    2.263 0.356 279.0 1.857 0.653 278.9
    3.405 0.534 419.0 2.131 0.853 418.0
    4.480 0.543 559.0 2.833 0.856 558.0
    5.680 0.534 698.0 3.780 0.802 697.0
    6.800 0.537 839.0 4.780 0.762 837.0
    Summary
    POWER ENERGY SAVER will allow you to enjoy your comfortable lifestyle without worrying about your electricity bills. In fact this advance energy saver can reduce your electric consumption and therefore your electricity bill.
    POWER ENERGY SAVER is designed using advance components and technology to reduce the energy wastage caused by the motors like the Air-con, Refrigerator, fish pump, Lighting, computer etc."
    bibili din ako sana neto dati eh, kaya lang wala rin akong nakuhang feedback from friends who are actual users, puro written testimonies lang pinakita sa akin ng ahente.
    i'll monitor this thread, interesado ako eh. ;)
    Originally posted by nap123
    Summary
    Ang alam ko, hindi applicable ang power factor correction sa residential consumers kasi wala namang power factor adjustment sa billing nila.
    Moreover, Meralco lang ang may power factor adjustment, so even non-residential but non-meralco-supplied consumers ay di magbe-benefit dito.
    Kung bibili at magi-install kayo nito, I would suggest na ang bayad is based on savings. Kung ano lang ang savings for the month, yun lang ang ibayad until fully paid. kung wala savings, wala bayad. Dapat pumayag supplier sa ganitong payment scheme kung talagang confident sya sa product nya.
    Opinion at suggestion lang po.
    Di ba pag hindi mo ginamit yung alloted consumption mo eh tataas pa din ang electric bill mo dahil dyan sa lintek na PPA na yan?
    Anyway, better if you can ask for a demo. Titingnan mo lang naman ang metro mo kung bumagal eh di ba?
    Jul 2003
    I just talked to the seller of this sa ads tv tel 721-000. Ang pagkasabi sakin pwede daw ibalik kung d daw talaga makaka save after 2-3 months of used. Bale sabi sakin mga 15-30 percent daw ang savings sa electric bill. This was design mostly daw kung gumagamit ng motor ang device like aircon. Tatlo pa naman ang aircon namin. pero malamig pa ngaun kaya d pa matetest kaya sa summer nalang ako bibili. I hope worth it eto.
    true sinabi ng ad, it will lower the energy usage of electric motors but not electronic appliances like tv, computers, etc. it will work with electric fans, air conditioners, refrigerators, water pumps, basta may electric motor. power of electric motor = amps X voltage X power factor. since the power factor is normally 80% then there is a built in loss of 20%*** in the power that meralco supplies to all of us. theoretically the maximum power savings will be the amount of power factor correction and limitted only by the efficiency of the motor. so if it corrects the power factor from 80% to say 90% then that will be savings = 10% X motor efficiency in terms of power consumption (of electric motors only). if it corrects the power factor by 20% then it's savings = 20% X motor efficiency.
    ***this 20% built in loss in supplied electric power is due to the fact that the power generation is 3-phase, the power wave lags the voltage waves by 30 degrees resulting in a power factor of 0.80 or 80%.
    so adviseable yan if you have airconditioners, electric fans and water pumps. pag lights, tv, computer and other electronics lang nasa bahay mo, then it's useless.
    di lang ako agree dun sa claim na 30 percent savings kasi how can that possibly be bigger than the correction in power factor (1.00 - 0.80 = 0.20 or 20% maximum)?
    Sep 2002
    Sana nga this product could help. If it could, wouldn't it be listing as it's clients top industrial/manufacturing companies? Imagine if you could get even 10% savings on 1m+ power bills...
    large customer with power factor problem will not going to use this device. they will definitely use capacitors.
    Sounds Good... but we need actual feed back from the users...
    the device works on motors like fans and refs... but if you have electronic device like computers, TVs, etc. it doesnt work.
    KOREK!!! Purely resistive load will not benifit from this device.
    meron ibang option....install a ground or make a 110 volt line and convert all your equipment to 110 volt ... this one would definitely make an improvement in the bill...meron pang isa sa lights....use the small wattage but efficient illumination type (I saw a friend using 3watts bulbs with a 25watt equivalent light).
    just my 2 cents. peace.
    i think the saving that you will gain is that the appliances will be more efficient. example if you use to put your aircon thermostat to full now you can put it to 6 or 7. this will save you electricity. these thing have capacitors in it that stores power and releases it when needed.
    Sep 2002
    how would a capacitor work? pwede ba ang capacitor sa mga malalaking freezer? where would i be able to get such?
    google search power factor correction energy saver!
    google-google-google!
    hmmm... up ko lang... may gumagamit ba nito?
    araw araw kasi ang andar ng booster namin dito... baka makatipid...
    Oct 2004
    nagwowork ba siya for mga electric stove? di ata noh? walang motor eh hehehe Thanks...
    Dec 2003
    we use capacitors (looks like a giant fridge) on our diy hardware store, it really makes a difference on our 100k+ monthly bill.
    Hmm eye opener ang post ni Yebo... Samin kasi to be honest, A/C and ref lang ang umaandar for the most part, wala kasing tao sa house most of the day...
    With regards dun sa 110V conversion, ang alam ko walang kinalaman ang voltage sa consumption ng kuryente coz it's based on wattage.
    Sep 2002
    info on some power saving device
    http://www.clarkpublicutilities.com/...ves2002/3-02-3
    bluebimmer: saan ang source ng capacitor na gamit nyo?
Power Energy Saver
