Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
  1. FrankDrebin Guest
    #41
    Quote Originally Posted by alwayz_yummy View Post
    thermaltake fan...may pang socket 468(sempron 2) ba yan?
    AFAIK, socket A ang sempron.
    Alam ko meron. May mga adaptor naman na included. I'm currently using a hybrid between GW and TT. :D
    Aug 2006
    #42
    60mm hanggang 120mm fans puwede sa Socket 462. Ang problema e kung kakasya sa heatsink. Kung gusto mo yung mga 80mm katulad nung ke Frank Drebin kailangan bumili ka ng bagong heatsink o kaya nung mga plastic bridge katulad din nung blue na nasa ilalim nung fan.
  3. #43
    mali nga siguro....saan ka nakabili ng copper na yan? gumamit ka nung paste?
    Mar 2005
    #44
    Good advice. That's probably why our Athlon XP 1700+ min temp has gone up. I haven't changed the thermal paste in like 4 years.
    Yeah, the pump-out can happen in as little as a few months. In AMD's techdocs they specifically warn against using grease
    #45
    nice! watercooling!
  6. FrankDrebin Guest
    #46
    Sa Gilmore madami niyan. Be sure na pwede sa MOBO mo. Yung paste konti lang ang ginamit ko. Kapag sumobra, your fan and hs is useless. Just apply a thin and even llayer of paste. Use a prepaid cell/internet card as a tool.
  7. #47
    ah.. mga 2mm bead inaply ko...medyo sobra sa may makintab na nakausli sa cpu
    may sample naman ako,e....ung orig. na heatsink...nga pala, magkano ang copper?
  8. FrankDrebin Guest
    Feb 2005
    #49
    ask ko lang, anu normal working temperature range ng system and CPU?
    mines sempron2200, replaced ko ung CPU heat sink, kasi nasira ung clip for the CPU fan.
    sa bios, the CPU is registering 45-53 deg.C and the system goes from 20-30deg.C with the cover on.
    is this normal?the fan is registered to be running at 4680-4710rpm.
    naglagay me ng thermal paste, pero di ko sure kung kulang or sobra, basta mga approx. 1mm bead nilagay ko sa center ng processor....
    try reading from here www.extremeoverclocking.com you will learn a lot.
    My rig:
    Intel Core 2 Duo E6400 2.13 GHz (Stock)
    BFG nVidia GeForce 7900 GTX OC (670/1600)
    #50
    wow naka C2D si Tacoma. ok po yan. sa mga tsikoteers, bili kayo ng Intel processors hehehe.
    Jan 2003
    #51
    mga sir! how do i check the temp of my CPU?
    #52
    sir usually may built-in application that comes with your motherboard na nagmomonitor ng temp. ng cpu mo. you can also see it sa BIOS.
CPU and SYSTEM working temperature
