Results 331 to 340 of 954
July 31st, 2020 04:13 PM #331
August 14th, 2020 07:44 PM #332
lakas ng benta ng ryzen5 4500u laptops sa market. ryzen 4000s in general ...
August 18th, 2020 08:24 AM #334
I remember in the late 90s. 16mb of ram. We will convert few mb to a virtual drive . And then copy the game diskette to that virtual drive para mabilis ang game. At hindi na kailangan yung maingay na pag read ng diskette. [emoji23]
August 18th, 2020 09:39 AM #336
Anyone using a Ryzen 5 3600? How much of an overclock were you able to squeeze out of it?
I was only able to get it stable at 41.75x on the multiplier (from stock of 36x) * 1.28V. In the real world, it's doing 4.17 GHz on all cores. It's stable on Prime95, Blender, OCCT, and FAH. Cooler is a DeepCool GAMMAXX 400 V2.
I know I can push this further but I think the cooler is the limiting factor. As it is, my thermals are already peaking in the low-mid-80's out of the 3600's max temp of 95°C. That said, I'm sure it would've ended up with much worse performance if I used the stock Wraith Stealth cooler. Maybe I'll switch to a Noctua NH-D15 or U12S or even the venerable U12A. That would tide me over until I've saved enough gas money for a 3950X.
Call me old-fashioned but I still have a disdain for AIO coolers... it's got one too many moving parts that can fail. High-gain, high-risk. Give me a massive CPU air cooler anytime.Last edited by oj88; August 18th, 2020 at 10:33 AM.
August 18th, 2020 10:04 AM #337
^What's your motherboard?
August 18th, 2020 10:50 AM #339
In a way, nakaka-inis din yung Type-C... kasi not all are the same.
Yung charger ng T495s and MacBook Pro ko ang lalaki...
Tapos yung PowerPort Atom na gamit ko dati sa MacBook 30W lang pala. so di nya kaya icharge yung both laptops ko ngayon...
Naghahanap tuloy ako ng 100W++ na GaN charger.
August 18th, 2020 11:53 AM #340
It's a gaming mobo so I suppose the VRM thermals are good but then again reviews on YouTube show otherwise MSI bazooka turned out to be better than gigabyte AORUS with B550 chipset..monitor also your VRM temperatures..it takes 4 to tango in terms of overclocking a PC Power supply, VRM, CPU and the cooler
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
