Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Dec 2002
    i'm using Yahoo Mail, and the "buttons" doesn't seem to work. when I click on "Check Mail", "Compose", "Search Mail", "Delete", and all those other buttons... nothing happens. even when i click on the "Empty" link on my Bulk/Trash Folder, i get no response. it was working fine naman before.. then all of a sudden di na siya gumagana.
    what should i do?
    help me naman please! thanks!!
    it seems to me that browser problem..kung nagana naman ang mouse mo sa functions off line... baka browser mo may problema.
    Dec 2002
    the mouse works fine.
    what sort of browser problem is this? how do i remedy this?
    desperately need ur help tlaga mga bossing.
    thanks!!
    does this also happen on other websites?
    Dec 2002
    yes.
    there were several instances where i filled up some online forms.. but when i click on the "submit" button, nothing happens. as in walang response. so i'm pretty sure the problem is from my end. i just don't know how to fix it.
    please help me. please!
    why not try running spyware removal tools (i.e. Adaware, Spysweeper, CWShredder and HijackThis), baka spyware lang yan...
    Jun 2004
    Your problem is your browser probably related to javascript.
    Just reinstall your browser and reset settings.
    i was thinking of that too... but if he doesn't have a copy of IE6.0 (or newer) at hand, it would be a long wait to download a copy from the internet via dial-up.
    Jan 2004
    Baka po naka-disable ang scripting. Check your settings.
    Aug 2003
    try mo raw mag install ng mozilla or firefox browser and see if the problem persists.
    Dec 2002
    car_girl,
    saan po ako makakakuha ng spyware? does it take long to download?
    ice77 and ghosthunter,
    mga bossing.. yup, i think the problem is related to javascript.. kse napansin ko na if i try to click on a link or button that requires javascript, hindi siya gumagana. tama ka rin sir ghosthunter.. wala akong copy ng IE.. and i'm using dial-up. paano kaya ito? where can i get a copy kaya (apart from the internet)?
    the_wildthing,
    sir, i went to "internet options".. clicked on the "security" tab and "advanced" tab, and restored everything back to the default level.. pero it's not working pa rin.
    badkuk,
    sir, saan po ako makakakuha ng copy of mozilla or firefox?
    schizo u can download spyware removal tools online, you can try any of the following:
    Adaware
    Spy Sweeper
    HiJackThis
    Mozilla web browser
    Dec 2002
    btw, can you please also give me the website kung saan ko pwede download yung IE?
    worst comes to worst, i'll just brave the long wait.
    salamat tlaga sa mga tulong niyo!
    Aug 2004
    Also use:
    www.security.kolla.de
    or
    http://www.safer-networking.org/en/index.html
    this is SpyBot... I use it in conjunction with AdAware.
    Schizo, it's better to use Mozilla. It doesn't get trojans like IE does. No more webpage hijacks, trojans or any of the associated bullsh*t that you go through with IE. It's free atsaka maliit lang ang download. I have it installed as the web-browser on all my computers, and I haven't regretted that decision at all... My IE used to go down at least once every two weeks due to viruses and trojans, and I used to get hijacked every month. I don't get any of those problems anymore.
    Dec 2002
    update:
    i started to download IE from the internet... i'm using dial-up so the estimated time was approx. 1 hour. i was about 80% done when...
    you guessed it...
    my computer hangs. bad trip! why does this always happen to me? hehehe...
    anyway, i started fiddling around with the computer...
    i went to My Computer - Control Panel - Add/Remove Programs
    i then highlighted "Microsoft Internet Explorer", and clicked on Add/Remove.
    i was surprised by what happened next...
    it gave me 3 options:
    - Add a component
    - Repair Internet Explorer
    - Restore the previous Windows configuration
    "Repair Internet Explorer"!!! That's exactly what I wanted! I was 99% sure that this would fix the problem since we all concluded na may problem yung browser ko...
    anyway, ok na!! tama kayo.. yung browser ko nga ang may problem. thanks to all who replied in this thread! laking tulong tlaga!! i don't really know what caused the problem in the first place, pero i'll definitely check out all those spyware and browser programs that was mentioned in this thread.
    once again, thank you and more HP!!
    best way to eliminate spyware/adware is to do the following:
    1) Spybot Search & Destroy 1.3
    2) Lavasoft Adaware SE (don't forget to download the latest definition file as well and upgrade)
    3) Spyware Blaster 3.2 by JavaCool Software
    the first two as most of you know remove spyware/adware/malware. BUT using only one does not cut it. I've found that after almost a year of usage in an enterprise environment, using both eliminates virtually all spyware (as long as you keep yourself updated).
    the 3rd one basically prevents them from ever being installed in your computer in the first place. (also constant defintion upgrades are needed) in order to be totally protected.
    hope this helps.
    on a side note... DSO Exploit that is seen in spybot search and destroy is a windows flaw. you need to edit a registry entry for this option to go away (clicking on fix it on spybot and restarting and doing another scan will make this come back coz it was not really fixed w/o manual registry editing).
    if you wanna know how to do it, just msg me.
    P.S.
    make a backup of your registry before doing such.
    i've tested this combination for almost a year and i have yet to be infected by spy/mal/adware.
    "the price of freedom (from virii/spy/ad/malware) is eternal vigilance"
    just a little thing i noticed with spysweeper... it seems to be prone to crashing your system... which is why i stopped using it.
    Oct 2003
    I think its better for you if you remove the IE in your system and substitute it with Nestcape 7.0 and up. IE is pathethic! I suggest you don't install any of the spywares and stuff coz it will only do you harm. Better to stay away with (.exe, .scr, .com, .doc, etc) file extensions. Just ignore the popup and the auto install java scripts. Also have a clean bootable disk for safety purposes.
    I know someone who infected his PC installing spywares and others like (Spyware, ADware, Java killa, Spybot).
    All you have to do is:
    1. Have a backup HD
    2. Updated Anti viurs software
    3. Cd write all your important files
    4. Clean bootable disk
    5. Bootable AVP disk
    6. Ram upgrade in case you want your AVP always on.
    infected in what way may i ask?
    no matter what PC browser you use, you will always get spy/mal/adware... only mac browsers are immune to this... i have not tested linux browsers just yet.
    I use the programs I stated in a corporate setting and IT Security is my profession.
    FYI: even if you have the latest antivirus software, you still aren't safe. Symantec Antivirus Corporate Edition 9.0 does have a spy/mal/adware detection feature but it isn't done as extensively as the programs stated above (not to mention the 3 programs above are highly recommended by security sites and other reputable sites like cnet.com / zdnet / etc.)
    from cnet.com
    #1 Ad-Aware SE Personal Edition popular
    #2 Spybot - Search & Destroy popular
    #22 22 SpywareBlaster popular
    http://www.download.com/3101-2001-0-1.html?tag=pop
    staying away from exe / com / doc files is also not advisable due to them being important files that people need to use. com/exe files are the applications that you need to run. doc files are ms word files which are used extensively.
computer experts, need ur help!!
