Results 11 to 20 of 41
August 21st, 2015 04:57 PM #11
sabi nung nag install sakin pwede daw. nung ginawa ko bridge mode walang internet going to the router tapos i can only access the admin page when connected by wifi.
what is weird is may internet ako pag connected ako via wifi dun sa modem pero pag via cable wala. kaya wala din internet yung router ko.
naibalik ko naman sa route mode. you could try it i guess.
August 21st, 2015 10:39 PM #12what is weird is may internet ako pag connected ako via wifi dun sa modem pero pag via cable wala. kaya wala din internet yung router ko.
- Jan 2013
- 14
- Oct 2009
- 102
August 22nd, 2015 05:27 AM #15Maybe you just need a DDNS solution or a cloud DVR solution. Search for CCTV on cloud or CCTV on DDNS
August 22nd, 2015 12:24 PM #16
I think naka DDNS na ako. Parang url na ang nilalagay ko sa host field sa app na gamit ko to access the cctv remotely.
Signature
August 23rd, 2015 12:00 AM #17
I presume only the modem was changed & its not wifi capable
Then the new modem doesnt allow the port your application to monitor the cctv is using
To verify which ports are open on pldt end, directly connect the lan segment (bypass the wan) of your old wifi router to the ethernet port of the new fiber modem then use dyn dns tool via browser in the computer also connected to the lan interface of the existing wifi router. Dont forget to turn off the dhcp of your old wifi router
If it happens that the port is not open then you have to request pldt to open it on their end. otherwise youll continue to be cctv blindLast edited by kisshmet; August 23rd, 2015 at 12:17 AM.
August 24th, 2015 12:33 PM #18
What is dyn dns for? Googled it and it requires subscription.
Signature
August 24th, 2015 03:33 PM #19
I use DYNDNS to be able to access my ipcams at home remotely using my laptop and iPhone. It requires a yearly subscription. DYNDNS allows me to do some log-in with username and password before I can access my ipcams.
I also had problems with my ipcams and DYNDNS. I was informed that my internet subscription is "dynamic", meaning my IP address changes regularly (quarterly?). So my ipcams must be reconfigured every time. To avoid that issue, it was suggested that I request PLDT for static IP address for an additional fee. For now mine is dynamic.
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
