Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Dec 2011
    Hello computer geeks in this thread and hope you can help with my problem. I have an external Toshiba Canvio 1TB portable USB HDD and happens to be unaccessible right now. Each time I tried to plug it, the computer says "can't access the drive" and asking to reformat it which, I cannot afford to do. I tried running chkdsk on command prompt but no progress and always getting stuck on "CHKDSK is verifying Usn Journal...", waited for 5 hours and still stuck there. I tried running on /I and /C but same thing happens. I tried using Recovery Software (Recuva by Piriform) to recover whatever I have there but not all files were retrieve. Is there any possibility or way to fix the problem with my HDD? or can you recommend better recovery software if all other way fails? Please help me...thanks in advance!
    Nasubukan mo na bang palitan yung connector niya?
    Aug 2011
    kung puwedeng ibahin yung connector, then do so. saan ba kinakabit, desktop o laptop? kung isa sa kanila narerecognize yung external hard drive mo, mukhang reinstall mo USB controller mo. kung parehong equipment di madetect hard drive mo, check mo kung may ingay yung external. nasa warranty pa ba? try mo RMA. check mo website ng hard disk mo click here.
    Dec 2011
    I tried exchanging usb adaptors initially when I first encountered the problem. The computer detects it as drive G as it was before and until now but cannot access. All of USB ports of my laptop are working well and even my other external HDD. I've been using that HDD for more than a year now and the most important thing is to make it work again to get all my files there. My troubled HDD is still working when I tried running CHKDSK, I can hear the spinning and ticking as it searching for something. I can bring it back to life just to reformat it, but I will not do that unless I can recover back all my files and there's no way to fix it back without reformatting.
    Quote Originally Posted by palonmar View Post
    That clicking sound might mean there might be physical damage to either the platter or the head. Since you can still partially access the drive, it might be the platter.
    Aug 2011
    The old freezer trick only works if the problem is a stuck motor or stuck platter. For physically damaged platters, this will not do anything. As mentioned, he could see some of the files but not all.
    Aug 2011
    *thread starter, may clicking sound ba external hard disk mo?
    boot via Linux and try to access your drive there, if you can, file system problem. if you cannot, hardware problem.
    try Knoppix.
    Dec 2011
    It's not actually a clicking sound and not loud enough unless you put the HDD right next to your ear. It sounds just like when you play a CD or a DVD in your DVD drive as it looking for something but very quite. That sound appears for some time each time I plug it into the USB port and turns into smooth rotating sound after the computer detects nothing from it and right after the message appears as " You need to format the disk in drive G: before you can use it, Do you want to reformat it?". My HDD continously rotating smoothly just like my other HDD as long as it is plug into the USB.
    Sep 2008
    try mo download testdisk. nangyari din yan sakin before and i was still able to recover my files.
    Dec 2011
    It seems like my HDD does'nt have physical damage. After I tried installing another recovery software, it sees all my undeleted files there but does'nt show all my image files. It looks like I have a higher chance of retrieving all my files but cannot restore to its current state without reformatting. Is this about the recovery software that cannot detect image files? Or is there any recovery software that guys here can recommend that can do better?
    try recuva, if you are on windows.
    Aug 2006
    GetDataBack kahit ilang beses pa yan na-format. You just need another High capacity drive for recovered files.
    Try to look for cracked version.
    Oct 2011
    yan sakit ng mga portable HDD. try photorec to recover your file in your portable HDD adn buy a new one.
    Jun 2011
    ayaw na din bumukas WD ko na external Hard drive.... mukhang corrupted na.....
    seagate po ba matibay? magkano ba 1TB nun?
    Jul 2006
    based on experience, mas reliable ang wd. of course, depende sa gumagamit, pag laging natataktak yung hd, malaki chance na masira agad
    almost the same cost ang wd at seagate, around 5,400-5,800
    Oct 2011
    Hindi rin matibay ang Seagate as long as portable HDD, ganyan talaga. Go for portable SSD instead.
    Jul 2006
    ^ SSDs are still very expensive compared to portable HDDs. and aside from the price, limited rin capacity nya unlike HDs, na breach na ang terabytes
    portable WD are more reliable than seagate.
Can't Access My External Hard Drive
