Page 12 of 15 FirstFirst ... 289101112131415 LastLast
Results 221 to 240 of 291
    Mar 2004
    #221
    Bought a photo printer... having hard time connecting it to wifi... arrrggghhh.... maybe sa router ito.... next is to invest for a photo booth materials and software...
    then im good for small business nah... photo printing and photobooth rental...
    Are you using Windows or Mac? ...
    Bruh, been trying all day in windows10... wps method not working, set up wifi using usb connection not working... though printer is working when connected to usb... only wifi feature is not... now trying to connect it to wifi via mac...
    Na connect ko na sa wifi ang printer... Mac driver for epson l805 works pero sa windows, hindi siya ma connect... weird! So for my windows laptop, i have to use the usb connection for printing...
    Up next... checking the dslr photobooth software.... [emoji16][emoji16][emoji16]
    Mar 2004
    #224
    Weird indeed ... usually it's Mac OS that have issues with WiFi printers ...
    #225
    I have Epson L3150 and was able to connect my Windows 10 desktop PC to it over the network. Pero binind ko yung printer MAC address to 1 IP para if di madetect automatically ng mga devices, they can manually add the printer by entering the printer IP.
    Quote Originally Posted by marky2115 View Post
    Did this route through windows... i set up the manual ip address and makikita naman ang ang mac ng printer but still it did not connect to the router...
    may issue yata sa windows driver kasi when i use the mac driver, the same process sa windows, diretso2 connect nya...
    #227
    I just remembered I downloaded an Epson software that will launch a setup wizard and download the correct drivers. That actually worked for me instead of manually downloading a Windows 10 compatible driver from Epson Support page.
    Yup... i download the one in their website for windows 10 set-up and even used the cd installer that came with the printer but to no avail...
    Feb 2018
    #229
    error sa driver. try updating windows if meron. tapos reinstall drivers ng printer hehe
    Jan 2009
    #230
    I bought an Epson L3150 about a month ago (though, this will apply to any injket printer) and was scraping the internet on how to take care of it. Then I found this video and followed her advice. The darn tip works!
    TL;DR,
    Avoid using the printer's head-cleaning feature, especially Epson's Power Cleaning, as it wastes a lot of ink and reduces the service life of the ink waste pads. Instead, print out customized purge sheets so you can target only the color or printhead that needs cleaning. This also means, you're printing on paper and not spitting out the ink onto the ink waste pad.
    You can find tons of purge files on the internet or you can even make them yourself using just MS Word (the video will show you how). However, be sure to use a purge sheet that matches the number of colors your printer can print. The L3150 has 3 colors + black (CMYK). Other printers may have different shades of the same color (5 colors + black).
    Mar 2013
    #231
    TL;DR,
    Damn i needed this tip years ago.....
    Gave up on ink tank printers because of nozzle clogging.
    Sent from my SM-G998B using Tapatalk
    #232
    TL;DR,
    Good tip! Thanks for this.
    BTT hassle lang ma paper jam itong Epson L3110 unscrew and baklas ka talaga to clear it lalo na pag may naiwan sa feeder. Siraniko pa naman ako.
    Jan 2009
    #234
    ^ Been there. It’s frustrating.
    As a loss leader product, they recoup through the sale of consumables, unfortunately.
    #235
    IIRC the HP printers we've had have the heads built into the ink cartridges. Maybe that's why I never had an issue with any of our inkjets. Never had to clean the heads. Using original cartridges exclusively probably helped as well.
    #236
    Our Epson is skipping pages, errr let me explain.
    You are printing multiple pages then there will be a blank pages in between the printed documents.
    Hindi ko ma figure out kung bakit.
    #237
    folks,
    i am in need of a cheap but good basic monochrome laser printer.
    suggestions?
    #238
    folks,
    suggestions?
    How cheap is cheap Doc?
    #239
    no definite number, naman.
    cheap, price-wise and maintenance-wise. matibay.
    no need for automatic back-to-back printing, half-tones, wifi, etc.
    for plain document printing only.
    Jan 2009
    #240
    If you can get your hands on an HP P1102 or P1102w, kahit used. There's an abundant supply of compatible 85a toner cartridges everywhere.
    I sold my P1102w a few months ago but after going through 4 or 5 toner cartridges, it still worked like new. I had to rid of it to consolidate and reclaim desktop space when I bought an ink-tank multi-function printer.
Best Printer: Canon, Epson or HP? 3k Maximum Budget
