Results 21 to 26 of 26
Tsikot Member Rank 3
- Nov 2002
- 1,890
September 21st, 2007 11:47 AM #21Its all about power to weight ratio, but manufacturers quote is that almost 9 out of 10 smaller engined cars are more economical as compared to the same body and spec car with a bigger engine. And it depends on driving habits and condition. i know that a 98 E230 is more of a gas guzzler than the E240 with a V6 engine as according to manufacturer specs.
September 21st, 2007 12:56 PM #22
If you ask me, I think over-powered is much better under-powered.
With the over-powered vehicle, it will go when you need it to go and you don't need to stomp on the accelerator to get the power you need.
But with an under-powered vehicle, you really have to stomp the accelerator which will put great stress on the engine, which is not good for the engine nor the fuel economy.
Hope this helps.
My two cents
September 21st, 2007 01:07 PM #23
kung traffic--aanhin mo naman ang over-powered ride mo...
so tama parin ang--having the right tool for the job
September 21st, 2007 02:32 PM #24
Correct to a point.
A higher powered car is more economical in traffic if you don't adjust your driving style for the lower-powered car. If you keep egging it on for better acceleration, you'll get much worse fuel economy than a more powerful car whose driver is taking it easy.
A lot of the fuel-efficiency problems with low-powered cars here has to do with transmission design. With the proper transmission, a low-powered car should get much better fuel economy in traffic and under acceleration, too.
September 21st, 2007 03:21 PM #25
September 21st, 2007 08:42 PM #26
naiisip ko lang ^_^ underpowered+Turbo Kit = THE BEST ^_^
ksi experience ko sa Turbo Charged Engine ko ^_^ malakas sya lumamon pag piniga pero pag city driving tlgang tipid consumption.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
