Results 1 to 17 of 17
Threaded View
    Dec 2007
    Quote Originally Posted by gearspeed View Post
    Sinubukan ko kagabi yung run as administrator.Sabi kase ng kaibigan ko after ng extraction ko run as administrator yung set up.Ang nangyari ayaw pa din.Lumalabas log on failure: user account restriction.Possible reasons are blank passwords not allowed,log on hour restrictions or a policy restriction has been enforced?
    Hindi ko alam pero cd lang itong nabili ko.
    Enable mo muna ang Administrator account, then rerun the setup.exe as Administrator again...
    This is how to enable the Administrator account:
    goto command prompt (start > run > cmd), then type:
    net user administrator /active
    or:
    SUMMARY
    This step-by-step article describes how to enable the build-in administrator account by command-line in Windows Vista. This may be useful if you want to enable the build-in administrator to do some automation works without UAC elevation prompt.
    MORE INFORMATION
    To enable the build-in Administrator account, follow these steps:
    1. Click Start, and then type cmd in the Start Search box.
    2. In the search results list, right-click Command Prompt, and then click Run as Administrator.
    3. When you are prompted by User Account Control, click Continue.
    4. At the command prompt, type net user administrator /active:yes, and then press ENTER.
    5. Type net user administrator <Password>, and then press ENTER.
    Note: Please replace the <Password> tag with your passwords which you want to set to administrator account.
    6. Type exit, and then press ENTER.
    7. Log off the current user account.
    HTH... Please do update us if you succeed...
Adobe Photoshop CS3 Problem
