Results 1 to 17 of 17
    Dec 2003
    Extract ko yung photoshop cs3 dito sa newly reformatted pc dito sa bahay.Kaso after magextract may lumabas na "A problem occured while extracting some files check available space on your computer and the write privilages on the destination folder".
    Pinapalitan ko na yung cd ayaw pa din lumalabas pa din ang "A problem occured while extracting some files check available space on your computer and the write privilages on the destination folder".Tingnan ko kung saan ko nilagay yung files sa local c: para maextract nandun naman kaso kapag click ko yung set up ng cs3 ayaw niya maginstall.Ako naman ang admin ng pc.
    Sinubukan ko na sa ibang cpu namin sa bahay.Ayaw pa din same pa din ang nangyayari.Dati naman nakapag install na ako ng CS1 at CS2 dito sa pc ko.
    Ano kaya kailangan kong gawin para mainstall itong cs3?
    Thanks.
    sir, saang folder mo po ba ininstall?
    Dec 2003
    Extract ko muna yung file.Yung extracted file nasa program files.Gumawa ako ng folder para sa adobe photoshop cs3.
    Dec 2003
    Ito nahanap ko.Ito daw gawin ko Right click on the downloaded exe and select "Run as administrator" - no more permissions errors.
    Ang hindi ko maintindihan anong downloaded exe ang kailangan kong iselect to run as administrator?
    Is this before or after extraction of the file?
    Thanks.
    Oct 2008
    hindi naman siguro HD space problem ang tinutukoy niyan about sa check available space from your computer error so i cant think of any aside dyan sa troubleshooting nyong admin mode
    naka compressed pack pa ba yan? usualy kasi yung dvd installer, hindi na. autorun na yung dvd. I suggest getting another installer. if not possible, look for a portable version. unstable but you have nothing to loose.
    Dec 2003
    Sinubukan ko kagabi yung run as administrator.Sabi kase ng kaibigan ko after ng extraction ko run as administrator yung set up.Ang nangyari ayaw pa din.Lumalabas log on failure: user account restriction.Possible reasons are blank passwords not allowed,log on hour restrictions or a policy restriction has been enforced?
    Hindi ko alam pero cd lang itong nabili ko.
    hello, your using the vista version os tama po ba? again i second the motion you have to get new staller, most of the dvd are autoexec version with some menu to choice.
    maybe sira po ang nabili mong cd's..
    Dec 2007
    Quote Originally Posted by gearspeed View Post
    Enable mo muna ang Administrator account, then rerun the setup.exe as Administrator again...
    This is how to enable the Administrator account:
    goto command prompt (start > run > cmd), then type:
    net user administrator /active
    or:
    SUMMARY
    This step-by-step article describes how to enable the build-in administrator account by command-line in Windows Vista. This may be useful if you want to enable the build-in administrator to do some automation works without UAC elevation prompt.
    MORE INFORMATION
    To enable the build-in Administrator account, follow these steps:
    1. Click Start, and then type cmd in the Start Search box.
    2. In the search results list, right-click Command Prompt, and then click Run as Administrator.
    3. When you are prompted by User Account Control, click Continue.
    4. At the command prompt, type net user administrator /active:yes, and then press ENTER.
    5. Type net user administrator <Password>, and then press ENTER.
    Note: Please replace the <Password> tag with your passwords which you want to set to administrator account.
    6. Type exit, and then press ENTER.
    7. Log off the current user account.
    HTH... Please do update us if you succeed...
    Dec 2003
    Binalik ko na yung Photoshop CS3 na CD.Ang pinalit sa akin ay Photoshop CS.Nainstall ko naman.Sabi nung nagbebenta pagnagkaroon na daw sila ng CS3 na DVD balik ko na lang daw yung CS2.Wala naman daw kase gaano difference ang CS2 at CS3.
    in my observation, mas ram leaky yung CS2. I would suggest getting a CS3 or CS4 portables version.
    May 2010
    guys sino magaling sa photoshop sa inyo?
    share niyo naman pano yung ganito. alam ko photoshop tong ginawa sa kulay niya e kaya gusto ko matutunan sana.
    salamat!
    sa net ko lang kinuha mga images kaya paumanhin nalang sa mga taong may-ari neto. :peace:
    Mainly the photos were editted in their exposure and color balance (less reds because that is the first color to fade if a print is exposed to the sun). The last one seems to have a few "light flares" added.
    Personally I hate the "Instagram" look where the photos are artificially editted to have that faded look. I see it just a cover up for bad photography.
    Quote Originally Posted by piscesboy View Post
    salamat!
    visit or subscribe to Digital Photographer Philippines (DPP). there's a photoshop thread there.
    you'll learn a lot from the experts, including your inquiry......
    May 2010
    thanks boss! member ako dun pero matagal na kung di bumibisita, nakalimutan ko narin password ko. haha!
    Aug 2003
    you can also try playing around with filters and white balance settings sa camera pa lang.
    edit: but, yeah, the samples you posted came out that way via post processing.
    here's how you do it
    method1 fasterthantypingthis
    1. duplicate orig bg layer, so you have 2 similar layers on top of each other on your layers palette. purpose is to adjust the colour setting for the top layer and erase the area you've chosen to be your foreground subject
    2. select top layer-----image>adjustment>colorbalance
    3. those photos are horrible, anyways, if you target a similar shade, midtone setting for cyan and yellow=-30s (around negative 30s) and magenta=+40s. leave luminosity box ticked. click ok.
    4. to overexpose the image------image>adjustment>hueandsaturation
    5. did i mention those photos are horrible? eraser tool brushsize=175(larger?) with hardness=50%
    6. choose your foreground subj and erase it like hell. you can also use the polygonal tool with feathering for precise selection. you're done.
    7. for cheap depth of field--------filter>blur>gaussian
    8. for those glares, create a new layer, with the polygonal tool manually create varied shapes, fill it with white colour, blur it, and place two different glares on top of each other, the one on top should have an overlay filter on the layers palette
    method2 likeapro
    1. duplicate orig bg layer, so you have 2 similar layers on top of each other on your layers palette. purpose is to adjust the colour setting for the top layer and mask the area you've chosen to be your foreground subject
    2. select top layer, use the polygonal tool and mask your foreground subject either precisely at the edges or anywhere close to it. you'll feather it later, anyway. then select>inverse since we are after the area for colour adjustments leaving fg intact.
    3. make sure that the selection area is still active (moving ants), on your layers palette choose the add-layer-mask icon at the bottom. your second layer should have the duplicate bg icon with a small chain beside an icon that looks like pooh.
    4. choose the pooh icon--------select>refinemask. by now you should notice a big t*urd, i meant a mask over your foreground subject
    5. on your refinemask palette------feather=10 and you can contract or expand the mask if you wish via shiftedge. click ok.
    6. choose your duplicate bg icon and do the method1 steps 2 to 4. those photos are still horrible.
    7. you can always refine your mask setting by going back to method2 step 4 or simply dragging the mask icon to the trash without applying it, leaving the original and the duplicate layers untouched, otherwise you're done.
    8. for controlled dof, duplicate top layer, choose the mask icon, (step4) feather and expand the mask. click ok
    9. blur the image-----filter>blur>gaussian=1.5
Adobe Photoshop CS3 Problem
