Results 1 to 10 of 34
BANNED BANNED BANNED
- Jul 2003
- 2,267
February 13th, 2008 09:45 AM #1mejo madalas mag hang yung bagong PC namin. anu ba dapat i-check muna? gusto ko sana magka idea muna bago dalhin sa repair shop to claim warranty if ever.
amd athlon 64 x2
AS Rock motherboard (on board LAN and video card)
1GB memory (kingston)
150GB HD
I installed a firewire port
minsan nag-hang siya kahit na ordinary task lang ang ginagawa ko like browsing the web (using firefox). minsa naman pag nag capture ako ng vids from a video cam, wala siya problema.
any suggestions? tnx!
- Jan 2008
- 154
February 13th, 2008 09:54 AM #2
February 13th, 2008 10:08 AM #4
Try to clean and reinsert the memory modules...
if you have more than 1 mem module, try to take them out one by one. Maybe there's one mem card which is faulty.
February 13th, 2008 11:15 AM #5
madami eh...hangs can be caused by a lot of factors, namely drivers, yung operating systems mismo, installed applications or even the hardware.
hanggang ngayon may tinitira kaming PC dito sa office na naghahang din. among the activities that we have taken:
a) checked the cables inside. ok naman.
b) checked the system for virus. although may nakita na Trojan, nung natanggal, naghahang pa din.
c) since may nakitang virus, we assumed na baka may tinamaang DLL sa OS. so we repaired the OS. naghahang pa din.
d) we decided to clean format and clean install the OS. ganun pa din.
e) we have checked the RAM for loose connections. Ok naman.
f) we isolated a defective USB port. so assuming na yun ang nagiging cause, pinalitan namin ng USB. ganun pa din.
g) yun pala ang problema is yung CMOS...
February 13th, 2008 11:25 AM #6
-try to check your newly added hardware or software. if its started when you add these, maybe you need to uninstall this and check if your computer dont freeze up.
-Try also running your antivirus and some spyware removal tool. You may have virus or spyware/adaware that causes this freeze.
-You may also want to check your available hard disk space.
- Before in my desktop, overheating causes my PC to hang as well. you might want to check this issue as well.
- if ever you can also check the memory. try to run the memory diagnotic test. if it fails, you may want to reseat your memory. if it doesnt work, replace mo na lang sya.
February 13th, 2008 12:53 PM #7
ilang watts power supply mo? check the fans (power supply, processor), try mo ding tanggalin yung cover ng casing habang ginagamit mo, kung ayaw pa rin malamang may tama sa hardware mo.
February 13th, 2008 01:15 PM #8
Most of what I wanted to say have already been mentioned.......
But, you can still check System Information to find out which devices share an IRQ. Most have no problems. But, there are some that don't like sharing. If you find one or more devices sharing an IRQ, that may point you towards the right direction. Here's a couple of samples. Obviously, Vista is much better than XP in managing IRQ sharing......
Vista (Toshiba laptop)
XP Home (My main pc)
I also make it a point to disable in the bios any ports/devices I'm not using, eg: floppy drive controller, parallel port, idle com ports, RAID, etc
February 13th, 2008 01:26 PM #9
Check the IRQ's on all your add-in cards and see if it shares the IRQ with another device. That may clue you in.
- Jan 2008
- 19
February 13th, 2008 02:25 PM #10factor..
1.pls check processor fan
2.pls check OS or scan moh baka may virus..
3.hardware defecive: hardisk, ram..
naalala kong bigla... you can also have your valve clearance checked... baka di na sya nagsasara ng...
