Results 11 to 20 of 34
February 13th, 2008 02:27 PM #11
bro, di mo na-mention kung anung running OS ng pc mo...MS OS2k MS OSXP MS OSVISTA...dami kasi factors niyan lalo na't hang ang pinag-uusapan. bro, kung gusto mong wag nang maghanap ng problema niya...format mo muna yang PC mo at i-partition mo ng maayos yang harddisk mo po.
let say 25% for drive c. and 25% sa drive d and last partition is 50%..(assuming lang po yan, its up to you kung panu mo hahatiin yan.)kung naghang PC mo while installing OS, may prob na hardware mo...
kung natapos muna lagyan ng OS at mga drivers, observe mo muna..kung may hang parin..dun kana mag-test ng hardware kung anu na ang may sira...
just like me before, kala ko motherboard ang sira yun pala PSU lang.kulang pla sa power.
Good luck!
February 13th, 2008 03:02 PM #12
February 13th, 2008 03:09 PM #13
Diagnosing a "freeze" is a tedious process of elimination......
like browsing the web (using firefox)
It's important you analyze as many factors as you can before opening the case and messing with the hardware components.
Add: If your pc's under warranty, heck with this. Let your pc dealer deal with it.Last edited by Jun aka Pekto; February 13th, 2008 at 03:16 PM.
FrankDrebin Guest
BANNED BANNED BANNED
- 3,790
February 13th, 2008 09:05 PM #15Nangyayari sa akin yan pag medyo madumi na connections ng mga cards - usually yun video car ko.
so I just remove the card and use a pencil eraser to erase the contacts.
after that okay na ulit.
yung sa officemake ko naman, he had a defective RAM.
- Jul 2003
- 2,267
February 14th, 2008 11:25 AM #16ndi siya branded bru.
anu yung PSU?
will check muna yung watts ng system then check ung kaya nung generic avr. will probably buy a branded AVR siguro.
ok. will check these as well as the hardware connections. minsan kasi yung monitor ko bigla ding nagwawala. blue and white diagonal lines lang lumalabas.
i am a windows XP corporate edition. i am using the same OS dun sa lumang laptop ko na Pentium 3 lang. wala naman problema sa laptop.
February 14th, 2008 12:35 PM #17
That may be a sign of either overheating or insufficient voltage getting to the monitor..... But, you mentioned the video is integrated. So I'm leaning towards the power supply (PSU).
What's the watt output of your PSU and the brand?
Better yet list all the hardware you have in your pc to include the number of:
internal hard drives
optical drives
any unpowered external usb/firewire/sata devices
number of cooling fans (including cpu)Last edited by Jun aka Pekto; February 14th, 2008 at 12:44 PM.
- Jul 2003
- 2,267
February 14th, 2008 02:16 PM #18what do you mean by power supply? the AVR or the one inside the casing?
i have these in my PC
1 160GB hard drive
1 DVD-ROM
1 External DVD writer (connected through USB)
1 firewire card
1 cooling fan (yung nasa case ng CPU)
1 fan dun sa processor
1 1gb ram
2 sets of USB ports (4 ports sa likod, 2 sa harap)
thats it. wala masyadong nakakabit. basic lang naman.
- 3,790
February 14th, 2008 02:31 PM #19yung inside the casing ang ibig niyang sabihin na PSU.
wala bang waranty yan unit mo?
February 14th, 2008 02:49 PM #20
tanggalin mo muna yung AVR mo. yung mga AVR na hindi branded hindi maganda yung sinusupply na kuryente minsan yun pa ang cause ng pagkasira ng PC.
Monk-owned R53
