Results 1 to 7 of 7
June 25th, 2003 03:58 PM #1
ei,guys.im a 1st time diesel-user.jst got a kia carnival.nothng wrong w/ d ride so far bt i plan 2 have d oil changed ahead of d regular skedule.xcted na kc ako magpa-carbon clean & doc diesel recommended that car be in good condition 1st b4 having d procedure done.i saw on d oil specs database that REV-X was the cheapest synthetic oil avlbl.hav u tryd it on ur ride?does it give bang 4 ur buck?tnx
.....after this, il try dat biodiesel...& maybe replace d headers exhaust...& do d 8 washer method...TSK!TSK! BAD INFLUENCE TALAGA KAYONG MGA TSIKOT/DIESEL PIPS :twisted:
June 25th, 2003 04:11 PM #2
wulf, dude, general consensus ng oil gurus natin is that Petron's Synth for diesels is A-OK! Mura pa!
Tsikot Member Rank 3
- Dec 2002
- 636
June 25th, 2003 04:26 PM #3wulf,
Would recommend Petron all terrain if your diesel ride is quite new, ie, doesn't eat any oil. But suggest you do at least 5k km on mineral oil before using synthetic oil.
June 25th, 2003 05:40 PM #4
I am using 10 liters of Petron All-Terrain oil for my TD42 engine. Mas matipid sa Mobil, since I religiously follow the 5K kms. oil change.
FrankDrebin Guest
June 25th, 2003 06:39 PM #6
yan din sana ang gusto ko gamitin sa patrol ko pero wala ako mabili dito sa amin kaya nag castrol muna ako. almost 9 liter naman para sa 3.0 engine ko.
Signature
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
