Results 1 to 10 of 27
- 48
November 24th, 2003 08:42 PM #1guys question, in AT kelan ba mag shishift to 2?
while in motion ba? or what?
thanks!!
November 24th, 2003 09:15 PM #3
I think 2 is used to make the car move from a full stop if your driving in ice or snow right?
November 24th, 2003 09:17 PM #4
Leave the O/D on and let the ECU do the thinking. Put the O/D of when climbing or descending long and steep grades or when towing. Otherwise just keep it on.
You use "2" when you want the transmission to shift only up to second gear. Just use your better judgement. Just exactly when do you need a manual transmission to go only up to second gear? Let that be your guide.
November 24th, 2003 09:58 PM #5
Follow up question... O/D off only works with "D", right? Useless mag O/D off with D2 or L?
November 24th, 2003 10:26 PM #7
Yup O/D will work only in D because in "2" and in "L" you will not reach the overdrive gear. Kasi nga restricted to second and first gear respectively lang.
November 24th, 2003 10:41 PM #8
Thanks Masters mbt and OTEP...
OT: parang weird lang yung naming ng O/D on and off. Feeling ko dapat baliktad... If you need more power, dapat O/D on ang tawag, not O/D off. Kasi there are 2 variants of A/T, di ba? With and without O/D. Eh yung mga without O/D, they can reach the 4th gear by default. Wala lang... just blabbering nonsense...Last edited by paolorenzo; November 24th, 2003 at 10:43 PM.
Tsikot Member Rank 4
- Jan 2003
- 2,979
November 25th, 2003 01:33 AM #9questions pa ulet mga sir. correct me if im wrong... yun AT na may overdrive ba uses the belt system? pag off sya ay less ratio kaya more torque ang nakukuha but less speed? pag on naman ay less torque but more speed dahil sa nagpalit ng ratio yun gears?
yun lower gears yata are for ascending and for descending steep hills or roads.... uubusin kasi preno mo lalo na pag di ka gagamit ng engine stop so ang max speed ata pag off ang overdrive is 50-60 kph.. im not sure sa gas engines.. di ko lang sure, just correct me if i'm mistaken.
November 25th, 2003 09:33 AM #10
oo nga po follow up lang pag pa baba ng baguio (marcos or kennon) anong maganda gamitin naka off yung over drive with "D" ? kasi parang sobrang bilis naman kung walang engine break tapos pudpud ang breaks.
tnk u po
Yup nakakalaki ang bright colors and dark colors nakakapa-***y hehe
2023 Ford Everest Owners Thread
