Results 1 to 10 of 21
Unregistered user
- Jun 2003
- 1,122
September 12th, 2003 09:38 PM #1i was browsing the net and managed to stumble upon this site http://www.ultimate-accessories.com/...te-strada.html
way cool...
anyone had 1st hand experience with this?
or at least what can you say?
it stated that you can fit 33" on the strada
dba parang you need to regear na?:drool:
September 12th, 2003 10:46 PM #2
there are four stradas here that has this lift. i have seen it being installed and the parts were good quality. nagiging spring over axle ang rear and front drop down. they use 33" tires here all of them one is using TSL Bogger. They also make a lift for the ranger. it will cost you around 80k plus shipping.
Unregistered user
- Jun 2003
- 1,122
Unregistered user
- Jun 2003
- 1,122
September 12th, 2003 11:04 PM #5
as far as i can remember lang, mga 4 years ago na install eh. wala pa nga instructions pictures lang. it comes with 4 shocks, lift block for the rear, driver side CV joint (longer than stock), sway bar extension, torsion bar mounting extension, brake lines, knuckle extension ( dont know iif this is the right term), lower A arm bracket na extended, optional ang torsion bars. mga 4 inch lift ang labas nya.
September 13th, 2003 12:07 AM #6
Sa RIDE Banawe naka-Ironman yung yellow Strada doon. But for the price, I don't think its really worth it. Mahal talaga mag-lift ng IFS.
Hindi ba kaya ang 33" with torsion crank + minor body lift?
September 13th, 2003 09:54 AM #7
The brand is only called ultimate, based form the pix posted. It is an ordinary suspension lift with body lift kits inlcuded. Most aftermarket suspension stores can do it locally.
Unregistered user
- Jun 2003
- 1,122
September 13th, 2003 08:39 PM #8Originally posted by OTEP
Unregistered user
- Jun 2003
- 1,122
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
