Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jun 2003
    i was browsing the net and managed to stumble upon this site http://www.ultimate-accessories.com/...te-strada.html
    way cool...
    anyone had 1st hand experience with this?
    or at least what can you say?
    it stated that you can fit 33" on the strada
    dba parang you need to regear na?:drool:
    there are four stradas here that has this lift. i have seen it being installed and the parts were good quality. nagiging spring over axle ang rear and front drop down. they use 33" tires here all of them one is using TSL Bogger. They also make a lift for the ranger. it will cost you around 80k plus shipping.
    Jun 2003
    WOW... saan yan sa manila?
    do u have them?
    Jun 2003
    so basically kasama na sa kit pati mga leafs shocks etc?
    as far as i can remember lang, mga 4 years ago na install eh. wala pa nga instructions pictures lang. it comes with 4 shocks, lift block for the rear, driver side CV joint (longer than stock), sway bar extension, torsion bar mounting extension, brake lines, knuckle extension ( dont know iif this is the right term), lower A arm bracket na extended, optional ang torsion bars. mga 4 inch lift ang labas nya.
    Sa RIDE Banawe naka-Ironman yung yellow Strada doon. But for the price, I don't think its really worth it. Mahal talaga mag-lift ng IFS.
    Hindi ba kaya ang 33" with torsion crank + minor body lift?
    The brand is only called ultimate, based form the pix posted. It is an ordinary suspension lift with body lift kits inlcuded. Most aftermarket suspension stores can do it locally.
    Jun 2003
    i dunno ayaw ko kasi body lift
    Jun 2003
    anyway im just dreamin
    di kaya ng powers ko ganun halaga
    Jan 1970
    lift blocks are dangerous aren't they?
    Jul 2003
    sheep ano ba auto mo?
    Jul 2003
    kung strada, kaya 33" on a torsion bar crank and shackles. kapit bahay ko ganun setup.
    Jun 2003
    bubbles
    strada
    anong brand ng shackles gamit nya?
    Jul 2003
    yung nabibily sa auto supply. 380 ang pair.
    Jun 2003
    yun lang ang papalitan?
    ilan inches ang lift nun? harsher ride? saan naman gawa yung shackles na yun
    Jul 2003
    yung shackles na ginagamit sa mga truck. mga 3 inches. di ako sure kung gano kataas, basta sinasagad ko. nope nearly the same ride. better cornering.
    lift blocks delikado sa front. Sa likod, acceptable na din. Basta isa lang at hindi patong-patong.
    Jul 2003
    yup. kung gagamit ako lift block max na 1 inch. kaya happy na ako sa coils. hehe.
    Jan 2003
    33???? eh naka 32 ako torsion crank lang. halos sagad na...hmmmm
    Jan 2003
    saang nabibili yang shckles na yan bubbles???
ultimate suspension
