Results 1 to 10 of 10
November 12th, 2002 10:08 AM #1
pa'no tanggalin tuyong bubblegum sa body without scratching the paint finish? thanks
- 3,754
November 12th, 2002 03:31 PM #4
why not try hot water?
similar lang yan sa adhesive ng mga body stickers.
dip the cloth into hot water then try to wipe the gum off.
November 12th, 2002 05:10 PM #5
ok yung hot water para lumambot muna yung gum... then kapag may mga maliliit na naiwan, kerosene surely helps... wag ka lang manggigil... remember patience is a virtue
November 12th, 2002 11:33 PM #6
colt45,
Pwede ba ang olive oil?
November 13th, 2002 09:56 AM #7Originally Posted by OTEP
bubble gum is removable by organic solvents such as kerosene or gasoline and by natural (e.g., cooking oil) or synthetic oils (machine oil). mas madali kung solvents, slower if oils pero mas madali rin masira paint mo kung solvents. DO NOT USE GASOLINE, it's strong enough to dissolve or ruin the glossy topcoat of your paint which is usually just wax or maybe a clear resin topcoat. hot water may help also in softening the gum, if it's effective. use it but if not, oil and kerosene (mixed) will do just fine.
minor trivia lang... did you know that bubble gum is made of rubber.... a low molecular weight food grade rubber that is. nilagyan lang ng sweetener and flavor para may lasa. so when you're chewing bubble gum, it almost the same as chewing your favorite tsinelas :lol:
mas matigas nga lang at walang flavor yung tsinelas :D
November 14th, 2002 02:32 PM #9
rsnald
November 18th, 2002 01:38 PM #10Originally Posted by 20vanda01
subukan natin kaya sa MRT to :mrgreen:
high idle RPM at engine start
