pa'no tanggalin tuyong bubblegum sa body without scratching the paint finish? thanks![]()
why not try hot water?
similar lang yan sa adhesive ng mga body stickers.
dip the cloth into hot water then try to wipe the gum off.
ok yung hot water para lumambot muna yung gum... then kapag may mga maliliit na naiwan, kerosene surely helps... wag ka lang manggigil... remember patience is a virtue
colt45,
Pwede ba ang olive oil?
olive oil? sows, e di cooking oil na lang, yung minola ha :lol:Originally Posted by OTEP
bubble gum is removable by organic solvents such as kerosene or gasoline and by natural (e.g., cooking oil) or synthetic oils (machine oil). mas madali kung solvents, slower if oils pero mas madali rin masira paint mo kung solvents. DO NOT USE GASOLINE, it's strong enough to dissolve or ruin the glossy topcoat of your paint which is usually just wax or maybe a clear resin topcoat. hot water may help also in softening the gum, if it's effective. use it but if not, oil and kerosene (mixed) will do just fine.
minor trivia lang... did you know that bubble gum is made of rubber.... a low molecular weight food grade rubber that is. nilagyan lang ng sweetener and flavor para may lasa. so when you're chewing bubble gum, it almost the same as chewing your favorite tsinelas :lol:
mas matigas nga lang at walang flavor yung tsinelas :D
rsnald
eto rin ba reason bakit bawal bubble gum sa singapore?minor trivia lang... did you know that bubble gum is made of rubber.... a low molecular weight food grade rubber that is. nilagyan lang ng sweetener and flavor para may lasa. so when you're chewing bubble gum, it almost the same as chewing your favorite tsinelas
to answer this question... ewan lang kung totoo to, naikwento din lang sa kin. minsan daw kasi, sa isang subway service sa singapore, basta sa train system nila, ayaw daw mag activate nung automatic door closer ng train. so the officials had to trouble shoot and shut down the subway system. turned out that someone plugged the sensor of the the automatic door closer with bubblegum. kaya ayun, they banned bubblegum in singapore.Originally Posted by 20vanda01
subukan natin kaya sa MRT to :mrgreen:
