Results 1 to 10 of 41
October 14th, 2003 06:20 PM #1
i sent my Pajero to Mitsubishi for tuneup. They found some problems with suspension. Some parts need to be replaced such as the following:
1. Upperarm assembly
2. Lower ball joint
3. Inner and Outer Tire rod
4. PipMan(??) arm
5. Idler arm
These will total to 30K+ including labor. I didn't seem to notice or experince any problem with the suspension. Should I trust Mitsubishi and go ahead with the replacement of the parts?
Thanks
- Jan 2003
- 21
October 14th, 2003 06:39 PM #2Expensive because they are quoting all original parts.
Better if you have someone who you trust take a look at it and give you a second opinion.
#4 pitman arm
October 14th, 2003 06:39 PM #3
better ask for second opinion.
ask mo na lang sila pajerokid, otep kung san sila nagpapagawa.
HTH
October 14th, 2003 07:10 PM #5
Pero hindi ba mas ok kung sa Mitsubishi gawin para may warranty at sigurado ang gawa?
October 14th, 2003 07:13 PM #6
i think afrasay's cousin ferdie can do those repairs..try to contact sir Alfred.
mahal nga nung 30K IMO.
October 14th, 2003 07:21 PM #7
I had a Pajero done in JP Wheels in Paranaque and changed almost the same parts. Used a mixture of OEM and 555 parts and it cost less than half if you search for the parts in Banawe,
October 14th, 2003 07:33 PM #8
30K hmmm may spoiler and foglamps na ako niyan plus sound setup he.hehe.
mahal nga.. if its okay 4 you.. sa servitek mo na lang ipagawa then genuine parts pa rin bilhin mo..
October 14th, 2003 07:41 PM #9
Parts alone will cost 20k then labor 10k .. so if i get all original parts, it will still cost a minimum of 20k kahit sa servitek or sa iba ko pagawa..
Do you thik pag sinabi ng mitsubishi kailanagn palitan, dapat na talaga palitan?
Have you encountered any incident na nang-goyo ang casa?
October 14th, 2003 08:42 PM #10
Definitely gold standard ang Mitsubishi pagdating sa parts and labor. The problem is the labor since most of the time ay twice more compared sa labas. The cheaper option is to use replacement parts (if available and have it installed outside. Try the suggestions mentioned above.
Sa local market ng automobiles, mostly uso yung paying more for less. Yung stripped ang maraming...
China cars
