Results 21 to 28 of 28
August 13th, 2005 08:32 AM #21Originally Posted by RedHorse
August 13th, 2005 05:11 PM #22
Question lang peeps, when does one do a complete brake overhaul? When does one change the brake fluid?
- Jun 2004
- 1,311
August 13th, 2005 05:14 PM #23Replace brake fluid would depend on driving conditions, usually 40t km. Check your car manual for the recommended interval. Complete brake overhaul pag mahina yung brakes at may leak cguro.
August 13th, 2005 05:59 PM #24Originally Posted by chris_d
- Jun 2005
- 73
- May 2004
- 102
August 20th, 2005 07:47 AM #26kung mag rereplace kyo ng brake fluid better change your fluid narin also use dot 4. way better than dot 3 and mas tatagal lifespan ng pads nyo.
- Jun 2004
- 1,311
August 20th, 2005 08:13 AM #27I dont think using DOT 4 would increase the lifespan of brake pads. Boiling point is increased which is better for high performance applications. If the car manual states to use DOT 3 however it is best to stick with DOT 3 brake fluid.
http://www.stoptech.com/whitepapers/brakefluid1a.htm
- Jun 2004
- 1,311
August 20th, 2005 08:16 AM #28You can also check these out:
http://www.stoptech.com/whitepapers/...rakesright.htm
http://www.stoptech.com/technical/
Xiaomi E-Car
