Results 81 to 90 of 134
Tsikot Member Rank 5
- 3,144
June 14th, 2003 07:48 AM #82Ungas,
Have u seen the ads at PDI, meron nang dealer ng dito, US brand, baka ikaw ang may-ari nito :lol:
Nanganak kasi yong aso noong isang kaibigan ko, kaya hinakot lahat ng lumang dyaryo, kasama na yong kahapon, kaya di na ma-post ang name at brand.
June 14th, 2003 02:04 PM #83
RedHorse::: Nakita ko rin po yung ads ng McCollough (spelling?) brand. From what I know, it is famous for chainsaw products and parts. Di ko po kaya magtayo ng HID business, masyadong malaki ang money involved. :mrgreen:
AFAIK, there are only two companies that manufacture HID Ballasts. Hella and Philips. Sa HID bulb Philips lang po ang gumagawa. Yung mga available sa market na iba't-ibang brands ay rebadged or may have been re-manufactured.
mdpo::: Welcome po sir. Kung bibili po kayo ng HID, better wait for a couple of weeks more. Balita ko magbababa sila ng prices. Heard from the grapevine that the H4 single beam type will be lowered to 25K while the H4 Hi-Low beam types will be sold at 35K. Imo, mas maganda pa siguro bumili ng locally available kits, kung may masira man na parts (ballast, fusible link, relay [4 lang ang paa]) mas madaling kumuha at meron pamalit.
June 20th, 2003 01:50 PM #86
got an email from the McCulloch distributor here... looks tempting as plug and play lang pala siya... what do you think guys?
For your japanese car you need H4
you decide if you need single beam/ low beam only (city driving) or
you need hi low beam (normaly use to overtake and out of town trips)
Basic HiD kit for single beam is Php 25,000.-- complete set 5500K color temp.
For the Hi-Low Beam H4 it is Php 30,000.-- complete set 5500K color temp.
dont need to replace anything in your car just plug & play & if you decide to change car, you can transfer the whole system & since you did not change anything, you can return the old halogen bulb back.
Brand : McCulloch
Technology : High Intensity Discharge ( H.I.D. )
Light source : Xenon Gas - Arc Discharge
Color temp. : 5,500K to 10,000K
Wattage : 35 Watts
Lumen : 2,700 - 3,200
3 times brighter 2 times more efficient 10 times longer lifespan
Greater light output
Lower power consumption
Increase road safety
Improve visibility
Comfortable driving
Plug & Play - no need to modify anything !
Also Available - H4 Hi - Low Beam
OEM Mfg. for - BOSCH, MITSUBISHI, SUBARU
June 20th, 2003 05:28 PM #87
mazdamazda::: All HID kits that I know of are plug and play. Your existing OEM headlight wiring will only be used for turning it on and passing flash. The ballasts are probably made in Japan. Their color temps are over rated, imo. Standard color temps are 4300K, 6000K, 8000K, 10,000K and some even have 15,000K. 8O I used to have the 4300K which is like super whites on Halogen measurement. My current bulbs are 6000K, which has bluish white color. And before I forget ask about their warranty. :D
- 17
June 20th, 2003 11:41 PM #88sorry ha, distributor ako, baka gusto nyo...
Original HiD conversion kits McCulloch USA, no rewiring needed, Plug & Play 1 year warranty, OEM for Bosch, Subaru & Mitsubishi. all size available, for all types of cars Even Hi-Low beam H4.tel 3092184 - 09175342496 for inquiry. 5500K - 10000K color temp available, white to purple!
- 17
June 20th, 2003 11:59 PM #89iam the distributor of McCuloch here in the philippines.
i have 1 year warranty ...
sorry ngayon ko lang nakita yung end nung thread ninyo
kung may question kayo sa akin sulat nalang kayo hid*post.com
or 9175342496 txt nyo i will try to answer all your questions ...
or see you tom. sa EB kung makilala ko kayo ...
landline 3092184
June 22nd, 2003 01:45 PM #90
hello guys, I am also planning to acquire HID kits but am planning to get CATZ brand since based on hidforum.com that these are the best and brightest brand available in the market.
Any suggestions please.
thanks,
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
